Rough Idling/Serious Stalling
Old Sep 21, 2002 | 06:19 AM
JUDE's Avatar
I had posted earlier how my idle was rough and after a couple of days it got worse, the car was stalling whenever the rpm's got below 2k, it was sputtering at higher rpms and there was a weird engine whine that started.
I removed the intake to clean it, but it was only on for 3-4000 miles and wasn't dirty
I removed the throttle body, but when I looked it was already clean. I only have 54k miles.
I don't think its the TPS since the check engine light never came on.
I checked the vacuum lines for looseness or cracks, but they seem fine.
I need help, any other suggestions, 'cause this car is undriveable.
I also need a backup plan in case I cannot get it to work. I have an extended warranty on the car and would probably take it to the goodyear by my house.
First, should I remove the intake before taking it to them, so they don't try to blame the problem on that (I really don't want to, since its was a pain to put it on)
Second, are there other places that would work on a slightly modded car without BSing?
thanks.
Old Sep 21, 2002 | 06:41 AM
KINGMAX's Avatar
Maybe IAC?
Old Sep 21, 2002 | 07:43 AM
I30tMikeD's Avatar
The TPS can cause problems without trowing a code. It may need to be adjusted. "How to" can be found with a search or the Haynes manuel. Maybe a fuel filter?
I had a bad idel and stalling. I adjusted my TPS, idel, and put in new fuel filter and all is well.
Mike D
Old Sep 21, 2002 | 07:55 AM
XxJ822xX's Avatar
Re: Rough Idling/Serious Stalling
thanks.
i have the same problem.....i stalled 7 times last night....i was told that i needed new spark plugs...i'm going to change them today....i'll let you kno if that works.
Old Sep 21, 2002 | 07:57 AM
DaddyMac's Avatar
I know what the problem might be.
I sent you an email Jude
litch
123
Jan 4, 2024 07:01 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
97_GXE
Sep 15, 2015 06:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
