Cornering Lights question
Old Sep 21, 2002 | 09:46 AM
The Gange's Avatar
Ok, I just put PIAA White Extreme 9004 in my headlight and damn they are bright. But now my corners look like **** cause they are dim(respectively) and yellow. The main question is can you rewire your corners to not only be brighter, but to match the headlights (Low beams and highbeams) If you can do this, do you need special bulbs, or will Polarg M14 (Custommaxima.com reccomendation) be fine?
Old Sep 21, 2002 | 10:51 AM
Jepht20's Avatar
Custom User Title...
refer to the 4th gen FAQ's...there is a write up on how to rewire your clearance lights that will make them look better and brighter.
Old Sep 21, 2002 | 11:16 AM
BC_95GLE's Avatar
Are you talking about you bumper or clearence light if you are talking about the clerance lights then all you have to do is take the bulb out shave the upper nub on the blub and place the bulb in backwards. Brian
Old Sep 21, 2002 | 11:25 AM
The Gange's Avatar
I am talking about the Clearance lights right next to the headlights. I know you can rewire them to make them brighter (or shave the nub?) But I want to know if you can have them bbe connected to headlights so when the headlights are on lowbeams, the corner lights are as well, and when the hi beams are on, same with the corners.
Old Sep 21, 2002 | 11:48 AM
maximised's Avatar
even with the clearance mod, they still look dim when you have aftermarket bulbs in, I too would like to know if the polarg 1157's will match better. Are they blueish or white?
Mad Dhan's Avatar
Um, are you saying that ur corner lamps are sometimes off? Anyway the only you can do its shave the nub make the bulb brighter. It will stay ON bright when u have ur headlights/highbeams on. So this will get the effect u are looking for. But let me tell u they are still gonna look yellow. You have to get new bulbs.
Old Sep 21, 2002 | 01:45 PM
iregula's Avatar
ditto but i think the corners get too hot
Old Sep 21, 2002 | 01:57 PM
Chino's Avatar
Let me tell ya something. I have the complete Custommaxima set up with PIAAs in my headlights and Polargs all around. The Polargs do match the PIAAs at ALL! The picutres in Custommaxima are missleading. You are better off going to Tirerack.com and ordering all of your Bulbs PIAAs, do not try to match them with Polargs. Polargs are blue! Not hyper white as they claim to be. Do not make the same mistake I did.
Old Sep 21, 2002 | 02:16 PM
maxhead's Avatar
Yes you can, but I don't know if that's what you want. When you look at the rewiring instructions on this site or at Maximadriver.com, then take your lights out to rewire them, this is what you'll see. There are two terminals going to the 1157 bulb for the corners, on for low (which is on all 4th gens). It's the one that is connected now. The other bulb terminal is for high. When you cut the nubs off and twist the bulb around or rewire it, you are actually just using the high bulb terminal. That's why the bulb is brighter.
You can rewire the brighter setting to come on with your headlights or blinkers by connecting another wire from another power source (turn signal, high beam headlights, etc.) to the high lead on the corner lights. Does that make sense? Keep the low lead wired like it is, and add a wire to the high lead that connects to another power source. Whenever you turn on that power source (turn signals, for instance) you send power to the high lead.
But, if you do that, your lights will be dim (like they are now) whenever you don't have your blinkers (or headlights) on, whichever power source you use.
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
Blackwind
Aug 5, 2015 06:35 PM
