Can anything reduce "bees-in-a-can" sound from a y-pipe?
Old Sep 21, 2002 | 11:11 AM
phenryiv1's Avatar
Mod her. Ate her.
Can anything reduce the "bees-in-a-can" sound from a y-pipe?
I am thinking of buying a warpspeed y, but the seller reported a bees in a can sound from it. Can anything be done during the install, or any changes be made through some welding or patch work to eliminate that sound? By the way, all other components will be stock.
Old Sep 21, 2002 | 11:21 AM
dko's Avatar
dko
duck and cover
Re: Can anything reduce "bees-in-a-can" sound from a y-pipe?
better flex section, better y-pipe or header wrap on the flex section.
Old Sep 21, 2002 | 11:25 AM
phenryiv1's Avatar
Mod her. Ate her.
Re: Re: Can anything reduce "bees-in-a-can" sound from a y-pipe?
So can I replace the flex section or header-wrap the section in the used y, or are you recommending just buying one that does not have that problem?
mtrai760's Avatar
'Trynna' is not a word
Header wrap works great.
Old Sep 21, 2002 | 01:36 PM
Dan 93 SE's Avatar
Bees in the can
The pipe your buying must be our earliest version. A unlined flex was used on these first few. We now use only premium lined flex sections. If you have a loud exhaust, you probably won't even hear it. Before install call our 1-866-801-9338 number, Monday/Friday 9-5pm CST. Ask Lynne about having Dallas cut out old flex and install a lined one. I can't remember how much we charge off hand, I do know its not too expensive. BTW weekly we are repairing our competiors y-pipes with unlined and crimped flex sections. Header wrap helps somewhat, but I have heard can increase likely hood of rust.Hope this helps.
Dan WSP
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Quickywd01
Sep 21, 2016 09:36 PM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
