rpms act weird
Old Sep 21, 2002 | 05:34 PM
adamlacey's Avatar
rpms act weird
Dont know if this is something I did to my car, but I recently changed my fuel filter and cleaned the throttle body, and now whenever I am driving my car is acting funny...
Whenever I push in the clutch it takes a long time for the rpms to back down to 800ish, they sort of fall real slow and hang out around 1200 before they finally fall.
It seems like a vacuum problem or something?
I dunno, or is it maybe some part... no ECU codes.. yet.
ANy ideas
Old Sep 21, 2002 | 08:27 PM
JP73
Re: rpms act weird
ANy ideas
I think the same thing happened when I cleaned out my throttle body. It has been a while and seems to be back to normal. Someone posted that the car will adjust after driving for a few weeks. Don't worry too much, it's probably nothing.
Old Sep 21, 2002 | 10:39 PM
TooMAX's Avatar
Re: rpms act weird
ANy ideas
Since you've cleaned the TB and it's working better, sounds like your base idle might be too high now and the ECU takes longer to knock it down. You can check it and adjust if necessary by using this procedure: http://home.earthlink.net/~max_faq/maintenance.htm#idle The idle spec is at 650 rpm, but I set mine to 750.
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
