a question about ypipe and boost
Old Sep 23, 2002 | 11:43 AM
Cumalot's Avatar
I have the 1st gen WSP ypipe, non-mandrel bent one. I ordered a new lined flex section from WSP which supposed to be better. I took the new flex section to a local muffler shop to have it install. I'm no welding expert, but even I can tell the welding wasn't really good. The ypipe had a buzzing kind of sound to it. Sounded like something was leaking out, air I suppose. I took some header wrap and wrapped the two spot where it was welded. The buzzing sound decreased, but it's still there. I wondering could this affect boost? The car feel strong, but not as strong as I thought it would feel. Comments? I'm thinking of getting a new ypipe.
Old Sep 23, 2002 | 11:53 AM
Jon91SE's Avatar
Pusssseeeehhhh
It could be an air leak , if you are planning on keeping this Y-pipe i would bring it back to the muffler shop that welded it ...
Old Sep 23, 2002 | 12:13 PM
Soon2BMaxed's Avatar
sounds like my problem. listen to it closely and see where the buzzing is coming from. mine is from the gasket between the cat and y-pipe. a new gasket you fix mine easily but if yours is where the flex was welded then you need to have a shop re-weld it.
Old Sep 23, 2002 | 07:53 PM
Dan 93 SE's Avatar
leaking y-pipe?
Cumalot, put your car on jackstands or get her up on a hoist. Look for any small holes on the welds, flanges. If there is black soot, you have a leak. The new lined flex section should be very quiet. Makes me think you have a leak. You can always start her up while on hoist, it should be pretty easy to pinpoint problem then. Good luck.
Dan WSP
Old Sep 23, 2002 | 08:22 PM
Bags's Avatar
VG Ridah's Biatch Hoe
if your thinking about any more HP.. PM sx7r he has a y-pipe that would help you greatly
IF you want another
But you could easily fix the flex section of this one. and yes exhuast leaks = lost HP
Old Sep 23, 2002 | 08:44 PM
Cumalot's Avatar
Re: leaking y-pipe?
Dan WSP
Thanks. I should have sent my ypipe to you guys to have the flex section installed. Doh!
Old Sep 23, 2002 | 08:50 PM
Cumalot's Avatar
Now that I think about it, when I put the header wrap on the welds, there was some black stuff on it. I thought the welds suppose to look like that. Great...
Old Sep 23, 2002 | 11:07 PM
ptatohed's Avatar
Licensed to Spell
Re: a question about ypipe and boost
What is your question Mike? What do you mean 'affect boost'? An exhaust leak won't affect your performance in any way if that is what you are asking.
Old Sep 23, 2002 | 11:13 PM
Cumalot's Avatar
Re: Re: a question about ypipe and boost
It doesn't affect performance? Are you sure?
Old Sep 23, 2002 | 11:20 PM
sryth's Avatar
Re: Re: Re: a question about ypipe and boost
I don't understand why it would affect performance either. It's an emissions issue, that's for sure, but a performance issue? Why would it be?
-Sryth...
__________________________________________________ ____________________________
'98 SE 5spd, Pebble Beige, PRCAI, Stillen Y, Stillen FSTB, ACT clutch.
Pacesetter STS to be installed this week!
Old Sep 23, 2002 | 11:22 PM
ptatohed's Avatar
Licensed to Spell
Pretty sure. If anything, it might help! It's just like having a more free-flowing exhaust. It's more of a problem as far as pollution (if your leak is before the cat) and sound - but not affected/decreased performance.
Old Oct 4, 2002 | 09:25 AM
Stephen Max's Avatar
An exhaust leak will most definitely affect performance if it is near an O2 sensor. Outside air can leak in (as well as exhaust leak out), and if the sensor detects it, the ECU will think the engine is running lean and correct the situation by enriching the mixture to the point that the engine can run very rich, causing poor idling, loss of power and bad gas mileage. Happened to me on two of my cars.
Old Oct 4, 2002 | 11:11 AM
xHypex's Avatar
Removing the ypipe completely may help in the high end, but exhaust leaks defintely hurt performance. They basically create turbulence and decrease the overall velocity of the rest of the exhaust that isn't leaking (especially with boost). The best comparison I can make is trying to drink from a straw with a hole in it.
Regarding the WSP flex sections they are great. I have no reasonator, and my exhaust is still quiet with no "tinny" sounds or bees.
-hype
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
