3 Headlight wires
3 Headlight wires
There are 3 wires going to the headlight, right... so are the wires 12V? I am asking because once I get HIDs, the high beam wire will be worthless.... so I plan on hooking something else up to it (maybe strobes or blue fog lights?) that needs a 12V source..... let me know... thanks
Re: 3 Headlight wires
yes, but is the high beam 12V?
Also, what do you think I should put in instead of the high beams?
the black wire is ground.
the middle wire is headlights
the last wire left is high-beam
hope that helps.
Yes.. I knew this... but I wanted to know if the voltage difference between the high beam wire and the ground wire is 12V.
Originally posted by 97GLES
on the 4th gen:
hope that helps.
on the 4th gen:
hope that helps.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
