0409 MIL code
Old Sep 23, 2002 | 04:18 PM
praetorian300's Avatar
0409 MIL code
Last night while driving the SES light randomly came on and i pulled the code 0409 when i got home. i checked on here and it says the code is for a malfunctioning oxygen sensor. after i reset the light i went and drove and the car as performing a whooooole lot better and when floored it would shift/acclerate a lot quicker. after i turned the car off again and started it back up, it was back to being its sluggish self. so im wondering if its the o2 sensor thats causing this or if it could maybe be a bad knock sensor or something like that which was reset when i cleared the MIL.... thanks
-doug
Old Sep 23, 2002 | 04:53 PM
maximachad's Avatar
Lifetime Maxer
Re: 0409 MIL code
-doug
It's definitely your knock sensor...that happened to me. Get it replaced, and your car should be back to normal. If the knock sensor is going bad and not telling the ECU to supply enough fuel, it can cause a knock which causes your ECU to retard engine timing. (This also happened to me). Since replacing the O2 sensor, no problems!
P.S. - You can do this yourself pretty easily, as I did. Most dealers charge around $180-$220 to replace it for you.
-Chad
Old Sep 23, 2002 | 05:35 PM
so did you replace both the o2 and knock sensors, or just the knock sensor?
Old Sep 23, 2002 | 07:10 PM
iwannabmw's Avatar
Re: 0409 MIL code
-doug
If the light comes back with just a 0409 code again, replace the 02 sensor. That can easily cause a loss of performance as well.
If you're not getting the knock sensor code when you read them, consider yourself lucky, as that definitely isn't the problem in your case then.
Old Sep 23, 2002 | 07:15 PM
maximachad's Avatar
Lifetime Maxer
Just the O2 sensor. Check after a couple of weeks to see if you're getting any codes. (Light doesn't have to be on) If you pull the knock sensor code after you replace the O2, then you'll need to replace that as well. Chances are you won't though. If you're only getting 0409, then the O2 sensor is your only problem right now.
-Chad
Old Sep 27, 2002 | 09:43 PM
hey everyone, im so proud of myself because i replaced the o2 sensor that was bad today, even though it took 1.5 hours. well after i replaced it i cleared the ecu AND disconnected the battery to make sure all the codes were out. the power delivery seems to be a little smoother but my acceleration is still below what it should be and the time to kick down at WOT is still slow. what else could be causing the car to run slow? i know the knock sensor could be causing this but it isnt sending out a code....any ideas?
Old Sep 29, 2002 | 12:22 PM
come on guys...suggestions?
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
