Steering getting loose
Old Sep 26, 2002 | 05:01 AM
dgeesaman's Avatar
Maintenance Monster
Over the past few months I've noticed that my car doesn't hold its line as tightly as I think it used to. At 60-80mph in windless conditions, I can feel the front end float a bit, pulling left-right in a wavy manner. Maybe it's just the road, but it feels more like the boat-motion of a Buick than imperfect road. When I bought the car at 46k it was _tight_.
Any ideas? Is there some portion of the power steering system that's worth a look?
97SE 5sp, all options, 87k. New Tokico blues, Suspension Techniques springs, alignment, balancing, and Dunlop SP Sport 5000s on stock alloy rims. Basically, I take care of maintenance.
Dave
Old Sep 26, 2002 | 05:07 AM
mzmtg's Avatar
Minister of Silly Walks
Make sure your tire pressure is correct and the same side-to-side. Also, get your alignment re-done. Make sure they give you a before and after printout of the settings.
Old Sep 26, 2002 | 05:33 AM
dgeesaman's Avatar
Maintenance Monster
The tire pressures are all exactly the same (+/- .5 psi by my best gauge), and the alignment is only 1000mi old. I don't have the alignment numbers in front of me, but I read them over when I had it done in August and they were barely out of spec before (due to the suspension switch) and are now dead-nuts on numbers chosen by the shop. Is there any particular alignment setting (toe-in, camber, etc) that might affect the tightness of the fine handling?
Not only that, but the car has displayed this looseness both before and after a new set of tires, shocks, alignment, etc.
Dave
Old Sep 26, 2002 | 06:13 AM
95Max's Avatar
Toe in better on center control - plow feeling on curves
Toe out loose on center feel - better on curves.
Old Sep 26, 2002 | 06:14 PM
ZeRo MaX's Avatar
if i have 18x7.5 rims.. and 225/40/18 tires.. how do i know what my tire pressure needs to be?
D Mason
Jun 21, 2016 04:43 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
