Speed 1 on A/C is not working....
Old Sep 27, 2002 | 08:07 AM
Ramius83
The other day I was driving and I noticed that whenever I put the A/C on speed 1, nothing comes out at all. However, speeds 2-4 do work perfectly fine. So, I searched on the .org (Bill and Ben would be so proud of me) and I found in the stickies, a thread about a resistor going bad. Here is the stickie:
There is a resistor assembly mounted on the air duct close to the blower motor. That part has failed. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved. Replacing the resistor assembly is something the home mechanic can do. The only tool needed is a Phillips screwdriver. The replacement part costs about US$25.
Now, that resistor controls speeds 1-3. If that resistor were to fail, would I be correct in saying that all speeds in return would not work, except for 4th? If this assumption is correct, then why does speed 1 not work, but 2 and 3 both work. Anyone know?
Old Sep 27, 2002 | 08:12 AM
njmaxseltd's Avatar
Re: Speed 1 on A/C is not working....
You got 3 fan speeds, that resistor "block" has more then one resistor in it. Three to be exact. Only one can fail, you still need to buy the whole assy.
Old Sep 27, 2002 | 08:15 AM
mzmtg's Avatar
Minister of Silly Walks
So, I searched on the .org (Bill and Ben would be so proud of me) and I found in the stickies...
Awwww, how sweet.....
Old Sep 27, 2002 | 08:17 AM
Ramius83
Re: Re: Speed 1 on A/C is not working....
D@mn, that's what I was afraid of. Thanks guy.
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
homewrecker
Sep 24, 2015 07:01 PM
