Figured out WHY our autos don't go past 4rpm at tracks
Old Sep 29, 2002 | 11:17 PM
  #41
BippuBenji's Avatar
Sexima, I think you were racing doing above 110 or so because going that fast it will help to turn the OD on so that it will jump a few rpms to engage 4th gear if your are flooring it. I tend to see lots of people on this thread saying that their Max shifts at redline which is 6000 rpms? I thought redline is 6600? At least mine is. And for times at the track, me and DCmax are going to be the first to run 14's auto n/a 4th gen here in MD this October. Has anyone on the whole board done 14.9 or better n/a yet? I've been to the track lots of times and have been getting great times though this past everyone at the track happend to be running a .5 seconds slower due to the humidity and I ran a best of 15.3 which I think could've been my high 14 if it was as cold as my 15.09 run back in June. Some people say manually shifting does nothing, though it'll truly work if you know what your doing, like the right time when to move the shifter up. Now if I was running high 15's would you guys believe me? I've learned lots of things about running at the track especially about the engine heat, of course if you run back to back runs your Max will get worse times each time. Let your engine cool at least 30-45 minutes before each run.
Old Sep 30, 2002 | 11:56 AM
  #42
Sexima's Avatar
You are right.
also about the redline being at 6600
I redline like it there. You have tried this method before right?
Was it better than just leaving it to D?
Old Sep 30, 2002 | 02:09 PM
  #43
JeepRage's Avatar
Originally posted by iregula
yeh dont mess with tranny it will come back to u
no it wont. OD off at any decent speed will put it in 3rd from 4th. i have 172,000 miles, i use OD off to occasionally slow down by coasting, or if a cop pulls behind me or any other jack@ss. its the same as manually shifting from 1st to 2nd, which i DONT do. i left it in 2nd autocrossing however, since the tranny never sees 3rd.
Old Sep 30, 2002 | 03:40 PM
  #44
Rave's Avatar
Originally posted by Sexima
You are right.
Yer thats correct. I checked last night and it is actually 6600rpm that redline begins, my Max prolly changes at 6500rpm though.
Old Sep 30, 2002 | 04:00 PM
  #45
Pseudopods's Avatar
I do that in traffic sometimes, kick it into second so the things not shifting constantly. Seems like a trans that shifts less should last longer, correct? That's why I use the O/D kill switch too. If it's *******, I'll hit the switch. I don't see it as any different than shifting a manual from 5th to 4th because you're going to slow. I'm kind of hoping a few other will chime in on this, as there have only been 2 or 3 of us that do his with no problems.
-Seth
Old Sep 30, 2002 | 04:09 PM
  #46
Rave's Avatar
-Seth
I agree because I like to use this feature (O/d off) when in traffic and it does seem logical that it is infact just a downchange from 4th to 3rd. It allows the car a much smoother ride by just staying in 3rd rather than changing up to 4th and back to 3rd or even 2nd all the time..
I would like to know for sure that it is not causing damage to the car.
Old Sep 30, 2002 | 04:27 PM
  #47
Sexima's Avatar
it shifts at 6rpm
Old Sep 30, 2002 | 04:30 PM
  #48
Rave's Avatar
it shifts at 6rpm
Not mine, the shift is right before the redline which begins at 6600 so I estimate the change to be at around 6400 or 6500 rpm...
Old Sep 30, 2002 | 04:34 PM
  #49
Pseudopods's Avatar
I think it depends on conditions. Sometimes mine will shift at 6K, other times, I'm in the red. Recently, we got some cooler weather here, lower humidity, and the max is running awesome! I can push it right up there to red before it'll shift. It does seem to shift at a lower rpm after it's really warmed up though.
Old Sep 30, 2002 | 04:45 PM
  #50
Rave's Avatar
That sounds about right it is pretty cold here in Melbourne at the moment, maybe 17c or less with no humidity really.
Old Sep 30, 2002 | 04:57 PM
  #51
costcowholesale's Avatar
so 95-96 shifts @ 6600 rpm & 97-99 don't??
mine shifts @ 6100.... 6200 when cold.
or i can manual shift.
Old Sep 30, 2002 | 05:06 PM
  #52
Pseudopods's Avatar
Nope... I got a 98, and I can push red almost any time I want. Like I said, just not when it's hot and humid out. Humidity seems to affect it more than heat.
Old Sep 30, 2002 | 05:11 PM
  #53
oh ok, what kind of rims do u have? 16 or 15 or???
Old Sep 30, 2002 | 05:16 PM
  #54
Pseudopods's Avatar
16's - stock SE wheels on a 98 GLE
Old Sep 30, 2002 | 05:43 PM
  #55
Rave's Avatar
We are all talking about auto's here yes? And when you say you can push it to red does that mean right up to 6600 or past into the red?
Old Oct 1, 2002 | 04:42 PM
  #56
Pseudopods's Avatar
Yes, I've got an auto trans.
homeyclaus
Sep 3, 2015 06:15 PM
Team STILLEN
Aug 10, 2015 04:29 PM
