Fuse cover Q
Old Sep 29, 2002 | 02:57 PM
fast97maxse's Avatar
Fuse cover Q
The fuse block cover (the 3 x 4 inch panel with the
finger-grab bit that's by your left shin when you drive) keeps popping off.
I can't see anything wrong with it, but it doesn't take much of a bump to knock it out of place.
Any suggestions on a fix?
And don't say tape or a screw - I want it to look stock and still provide easy access.
TIA
Old Sep 29, 2002 | 03:06 PM
Mad Dhan's Avatar
Re: Fuse cover Q
TIA
i have the same problem, i think i caused it too, oh well. I fixed it by using my hair dryer and heating it up good and just bending it slightly so it will put pressure on the surrounding area so it will not pop out all the time. Hope this helps. let me know how it works out
Old Sep 29, 2002 | 08:05 PM
96shogunmax's Avatar
and to think i was the only one with this problem
Old Sep 29, 2002 | 08:55 PM
Nismo's Avatar
you said no tape but im going to say this anyways, I used some electrical tape and wrapped the latch thats on the backside of the panel so that it fits more snug on the dash so it doesnt come loose anymore
Old Sep 29, 2002 | 09:12 PM
tifosiv122's Avatar
All those years I left mine off.
Erik
Old Sep 30, 2002 | 07:52 AM
Mad Dahn -
When you say you bent it,
you mean that you kind of straightened it out,
taking the curve out of it slightly
and in effect making it longer - right?
Sounds like a good solution...
Nismo -
When I said "no tape" I just meant that I didn't want to tape it from the outside and have the dash look sloppy.
I think I'll try both methods. Between the two the pannel/door should stay in place.
Thanks all
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Mar 29, 2016 11:08 AM
jonreidhead
Jan 6, 2016 09:38 AM
leatherneck
Sep 30, 2015 09:16 PM
