Doors lock when I turn on lights
Old Oct 2, 2002 | 08:24 AM
MaximusMax's Avatar
Ok, so I changed the bulbs in my windows control units to blue, and they look great. However, whenever I turn on my lights, the doors lock. Sometimes it happens right when the lights licks on, other times, it happens like 5 seconds later. It NEVER did this before...I've already locked my keys in my car like 4 times. What would happen, is I would unlock the door, get out....the second the door closed, it would lock again (this happened once with the car running....that F*****g sucked). What could be the problem?
Old Oct 2, 2002 | 08:31 AM
Vinipux's Avatar
Re: Doors lock when I turn on lights
hehe, I think you've discovered a new mod my friend, that's a really cool feature, what did you do?
on a serious note, you probably screwed up when you sottered it back together, take it apart and make sure that you didn't make any extra contacts, it can't be anything else
Old Oct 2, 2002 | 08:39 AM
thebigsadler's Avatar
Re: Re: Doors lock when I turn on lights
i don't mean to laugh but that is a great title.. i almost spit mountain dew everywhere.. good luck with your switches..
Old Oct 2, 2002 | 09:24 AM
GarthG's Avatar
This is correct. . . Somehow the door lock switch is getting power when the lights are on, and the only way this could happen is with too much soldier and it is bridging 2 connections. Check to see where this might be happening.
Old Oct 2, 2002 | 09:37 AM
MaximusMax's Avatar
I got into a "fight" with my locks a couple days ago! Turned on the lights, car locked...I unlocked it, the car locked...did it again...then again!! Well, the car won. I does seem like a cool mod...now, I have to figure out how to control it.
Old Oct 2, 2002 | 09:40 AM
redmaxpa007's Avatar
i SeE what you did therE
yep.. if the solder job was a little sloppy.. that would cause it..
you are not suppose to let the car win!!
Old Oct 2, 2002 | 10:22 AM
max_shop's Avatar
On my Mazda 626, when I turn the ignition key to "Acc", all the doors lock after about 5 seconds. I like this feature. Can I do something similar on my Max?
Old Oct 2, 2002 | 10:51 AM
GarthG's Avatar
I don't know if you can do it with the max, but just make sure you don't do it like the early Dodge Intrepids, anytime the car car was on and the door shut the doors would lock. . . We had one of these at work up until a couple months ago and people were always locking themselves out of that car.
Old Oct 2, 2002 | 11:16 AM
Lime's Avatar
Wow, that's so funny! No offense, it's just amusing.
Definitely a bridge that shouldn't be there, abut these guys already called it. I just had to post because omg...too funny.
Oh and I doubt there's a way to wire the max to wait a certain time period and then lock, like a VW or a newer Intrepid, because there are no other similarly timed things that you can tap into that I can think of.
Old Oct 2, 2002 | 11:36 AM
Vinipux's Avatar
no, but you can make your own, when MaximusMax fixes his "mod" he has to tell us what he did I want that, I'd put it in w/ a switch, so I can control it. I need a switch board, there are many things that I want to wire to a switch, where should I put it
Old Oct 2, 2002 | 11:41 AM
99maxi's Avatar
this happens to my max.. but all the doors need to be closed before u turn the key.. once u turn it the doors lock..
MaximusMax's Avatar
Oh, I will figure this one out...I have nothing else to do at work except figure out little crap like this. As far as putting a switchboard somewhere, I have mine mounted to the right of the stearing column...running 4 switches through it. Took about a day of design and about $20 for all the material.
Old Oct 2, 2002 | 12:13 PM
Nick97SE's Avatar
With my Viper 550, the doors lock automatically. All the doors must be closed for it to work, but about 5 seconds after you start the car, the doors lock. When you turn the car off, the doors unlock. This didn't happen when I had the stock alarm on. It was one of the features I got with the Viper alarm. I kind of like this feature.
I like the way my friends car is better. Whenever you take the car out of "P" or Park, the doors lock. Once put back in "P", then the doors unlock. I would like my Maxima to work like this because it gets annoying always having to unlock the doors to let friends in the car, or waiting the extra few seconds after your turn your car off to get out.
Later,
-Nick
Old Oct 2, 2002 | 01:34 PM
Eric99SE's Avatar
I feel your pain!! I had a similar problem about a year ago. My doors would just lock at will, at anytime. Incredibly frustruating. I had not tinkered with anything, or done anything else that I thought would cause this. My "solution" was to live with it!!
As a result, the demon possesing my car decided to move on to bigger and better things. For some reason the auto-locking feature just went away!
I know it's not the most helpful post, but good luck!
Eric
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
