KYB AGX Compatibility w/Eibach Pro-Kit
Old Oct 2, 2002 | 05:46 PM
MamboMax's Avatar
Hi,
Anyone run into problems with an Eibach Pro-Kit combo with the KYB AGX? I'm currently Cattman coilovers that have the KYB AGXs with Eibach 380 lb ERS springs in front. The front is dropped about 1.75 in, and the KYBs have no adjustment and have lost a lot of rebound damping. I heard that too much lowering can cause problems with the AGX. I'm thinking of using the Pro-Kit + AGX, but am worried that I might run into the same shock problem. Perhaps I'll go back to Konis instead and live with the rear adjustment hastle. Any comments?
Thanks,
Mike Magdaluyo
Old Oct 2, 2002 | 09:36 PM
krbga's Avatar
No...
problemas...they are a perfect match, easy install, no sounds, good height,plush,tight,firm ride. totall plug/n/play.
Old Oct 2, 2002 | 10:29 PM
MamboMax's Avatar
Thanks krbga.
Mike
Old Oct 2, 2002 | 10:57 PM
Kevin's Avatar
I agree. I think Eibachs were made for AGX's I had Eibachs with Toks, Toks were too soft for them
Kevin
Old Oct 3, 2002 | 12:48 AM
KWheelzSB's Avatar
Just to clarify. . .
It's not just the AGX's that will have problems if you go too low. ANY aftermarket shock/strut designed with OEM ride height to -> 1.5" lower than OEM WILL suffer premature failure, due to the extra abuse they take when you run at lower ride heights.
You know the deal: Ya wanna play, ya gotta pay!
Old Oct 3, 2002 | 06:46 AM
njmaxseltd's Avatar
According to KYB corporation, the only lowering kit they actually recommend for use with their AGX line up is the Eibach Pro kit.
Old Oct 3, 2002 | 08:41 AM
voltman's Avatar
Yup. Same with the GR-2s.
Old Oct 3, 2002 | 10:45 AM
MamboMax's Avatar
Hi all,
Thanks for your comments and insight into this issue.
Mike
maxima-junky
Oct 7, 2015 06:13 PM
dvcamp
Sep 18, 2015 10:17 AM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
