more problems with my reverse indiglos....
Old Oct 6, 2002 | 06:09 PM
venompwr2's Avatar
ok, i fixed my speedo and tach from sticking, so those work great now. however i have issues with the gas gauge. its reading lower than the amount of gas in the tank, and its not going down. i've driven 50 miles and that damn thing hasnt budged at all, so its stuck. how can i fix the indiglos to see if the fuel gauge is working, w/o having to take the whole dash apart everyfew days to adjust it?? This is getting annoying after onely 2 days, so any help would be appreciated!
Justin
Old Oct 7, 2002 | 07:55 AM
ssilva420's Avatar
Re: more problems with my reverse indiglos....
Justin
Try filling your gas tank all the way,, if the needle does not move then its probly stuck... Then i would suggest filling the tank again and manually moving the needle to the full position and see if it works from there.. just make sure that your needle is not touching ANY of the new guagues.. the indiglows should not have any contact with the neeedles.
Old Oct 7, 2002 | 05:26 PM
venompwr2's Avatar
Re: Re: more problems with my reverse indiglos....
I know i need to fix 2 of the gauges. the fuel works when i filled it up, but it wont go down at all, thats my worry- when will i be out of gas?? and i will have to reset it, cause i filled up the tank and it read less than full.
Old Oct 7, 2002 | 05:49 PM
Toolrocks's Avatar
Disassemble the guage cluster. Leave the clear plastic off and put the cluster back in temporarily. Go fill the tank up and manually move the fuel guage needle to the full posistion. Drive home, remove the cluster, ensure that none of the needles will touch the guage overlays and reinstall the clear plastic piece. Now put it back in your car and you should be good. If you're uncertain, you could drive around a few days w/ the plastic piece removed and make sure the needles all sweep w/o sticking. Then reinstall it correctly. Hope this helps, good luck.
Old Oct 8, 2002 | 04:33 PM
venompwr2's Avatar
thanks everyone, I decided to bust out the double sided tape and fix everything, now all the gauges work again. not to mention that screwing the gauges back on helps too...didnt dawn on me until 3 days after..oh well
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
dcam0326
Sep 18, 2015 04:52 PM
Lilfatz301
Sep 18, 2015 08:06 AM
