Adding shock sensor to factory alarm
Old Oct 7, 2002 | 07:00 AM
blakkrob's Avatar
I saw where someone did this but I think it was on a 1999 MAx and I have a 1996, In the Haynes manual the wiring for the two are different. Any one have the instructions on how to do this in a 1996(GXE auto).(what wires to use) I can kinda figure out the power and ground.
Old Oct 7, 2002 | 07:03 AM
amb4081's Avatar
Re: Adding shock sensor to factory alarm
I have one on mine. I didn't do it myself. I had a local shop do it for around 50 bucks. I can check which wires go where and post it. I have a 1996 as well.
Old Oct 7, 2002 | 07:17 AM
njmaxseltd's Avatar
EASY
Just use the negative trigger wire from the shock sensor and tap that onto the hood sensor. It's right on the radiator support on the drivers side.
Old Oct 7, 2002 | 07:39 AM
blakkrob's Avatar
I can do this without pulling the BCM?
Old Oct 7, 2002 | 07:48 AM
190hpKiLLA's Avatar
Granny Driven
Shock sensor to a factory alarm is not good. Here is why/... The factory alarm is activated by the cylinder inside the door. So if someone turns that cylinder with a screw driver then ur alrm is off. Then your rear doors are not protected either. Just spend $200 on a Attermarket alarm like VIPER. The Aftermarket Alarm turns on ONLY with a remote and can not be by-passed like factory alarm. In 20seconds someone can scan ur code into their remote. There are more things to it so its your call. Good luck.
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
Stagnet04
Sep 14, 2015 11:28 PM
