New I30t/not new to nissan and infiniti
Old Oct 7, 2002 | 09:41 AM
mayhem_J30's Avatar
Hola maxima junkies! I've been hanging out on the org for a while now, but this is my first post.
Picked up a 96 I30t this weekend. First day I got a CEL. Code 41. Easy enough, found that the IATS wasn't connected properly. I connected the sensor back together, pulled off the battery negative for a minute then restarted car and still got the same code. I followed the sensor cables and all of those seem to be in working condition. What else could be the problem?
I have a good voltmeter, should I check the sensor with this when the vehicle is running or when off and which side of the sensor should I check, the side mounted to the metal bracked or the opposite?
The I30 is for my GF...talked her into it. I've been a very active member over at NICO for sometime now. Since this is my GF's car I most likely wont be doing any engine performance mods, but only suspension, brakes, looks and normal maintenance. Gotta keep her safe! Already ordered eibachs and kyb agx's and have only had the car for 48 hours. I can't wait to get the car up in my garage and put em on. I'm also going to do a full fluid flush. brakes, engine, PS, tranny. I haven't looked under it yet, but I'm guessing you can change the VLSD gear oil too, right? I also got that foggy head light syndrome that seems to be frequently talked about here. I did a search for it and about 7 pages pulled up.
Anyway, glad to be here!
Old Oct 7, 2002 | 09:48 AM
JeffesonM's Avatar
living out of a maxima...
Welcome to tbe board! Glad to have someone new with car experience and forum experience.
Old Oct 7, 2002 | 11:17 AM
I30tMikeD's Avatar
There is not a whole lot you can do about the foggy headlights except getting the 99 jewel type. I did use a polish which cleaned and shinned them a little but there are always going to be pretty foggy.
It's good to have another I30 here. Any chance it's a stick?
Welcome
Old Oct 7, 2002 | 11:23 AM
mayhem_J30's Avatar
Welcome
ahahahaha...ahahahah.... no.
Old Oct 7, 2002 | 12:46 PM
BBaker025's Avatar
Welcome to the club Now you need some cefiro parts, If you got any questions bout the I30 you can ask me
Old Oct 7, 2002 | 01:03 PM
mayhem_J30's Avatar
brian, i already emailed ya.
Old Oct 7, 2002 | 01:05 PM
JoesMAX's Avatar
welcome to the board, you seem pretty knowledgeable about cars.. you just signed up and youre already searching?
have fun modding it, through this board im sure you will find better prices on parts than you would elsewhere
Old Oct 7, 2002 | 01:27 PM
mayhem_J30's Avatar
what do you guys think about that 41 ecu code?
Old Oct 7, 2002 | 02:02 PM
SLC I30t's Avatar
the 0401?
DTC 0401
Diagnostic Trouble Code 0401 points to a problem with the Intake Air Temperature Sensor.
The IATS is mounted in the engine air intake duct, downstream of the air cleaner filter. It detects intake air temperature and transmits a signal to the Engine Control Module. The sensor uses a thermistor, a resistor with a value which is inversely proportional to temperature. The IATS is not directly used to control the engine. It is used only for
diagnostic purposes. Therefore the engine should start and run normally, even with the Malfunction Indicator
Light on and DTC 0401 stored.
This malfunction is detected when ...
a) An excessively low or high voltage from the sensor is detected by the ECM.
b) The signal from the IATS is inconsistent with the signal received from the Engine Coolant Temperature Sensor.
Possible causes include ...
- Harness or connectors (The sensor circuit is open or shorted.)
- a faulty Intake Air Temperature Sensor
The IATS resistance values should be ...
- at 14 degrees F, 7.0-11.4 Kohms
- at 68 degrees F, 2.1-2.9 Kohms
- at 176 degrees F, 0.27-0.38 Kohms
For further information about the Intake Air Temperature Sensor please refer to the Chilton repair manual (page
4-16) or the Haynes repair manual (page 6-11).
Did you reset the ECU after you did the fix-a-roo? taking the terminal off for a few minutes wont reset it... over night 24hrs might.
HOW TO RESET ECU----> http://www.seas.ucla.edu/~cheston/images/reset.gif
Why did you laugh about the 5 spd? I have one, I'm a little offended. really I'm not offended.
Old Oct 7, 2002 | 03:15 PM
mayhem_J30's Avatar
Originally posted by SLC I30t
the 0401?
DTC 0401
thanks, i found that post earlier in a search. guess i just need to pull the battery cable off longer.
i laughed when you asked that because the 5 speeds are so rare, and i would love to have one.
Old Oct 7, 2002 | 04:45 PM
fst96se's Avatar
Welcome!
Another i30! I too have a 5spd...and if you need one, well I could help ya! I bought 99 headlights on ebay for about $60...I got a really good deal, I have seen them on there every so often for ~$150...
Old Oct 7, 2002 | 05:14 PM
TonyVQ's Avatar
Welcome on over!! Anything you need to know about your car I'm positive you can find the answer here!
Old Oct 7, 2002 | 05:43 PM
JoesMAX's Avatar
Originally posted by fst96se
Welcome!
wait a second... youre a cop and you have a radar detector?
Old Oct 7, 2002 | 09:37 PM
fst96se's Avatar
Quoted from an earlier thread....
"That is a good question and I have explained it before. There are a couple of reasons, not the least of which is that I am no longer a FULL time police Officer. I used to be, but now I am a Reserve officer. I am still a certified Police Officer employed as such, but I am only required to put in about 20 hrs per month, or two shifts. I went to school and got a Bachelors in Political Science and a Masters in Accounting because I thought someday I might go to work for the FBI....now I am making more money than I could with the FBI as a CPA and dig the job...and I can still patrol as an officer when I want to, which has always been my first love.
Second, the state police here is VERY militaristic, and will cut no breaks to anyone. They do NOT extend professional courtesy and if I got pulled over by them I could expect to get a ticket.
Third, I live near the UTAH border and travel into Utah very often....UHP doesn't like Idaho cops, I think because of the Idaho State Police, so I could expect to get a ticket there too. Point is, I can't speed and get away with it, and I would rather not be stopped....sound okay?"
Old Oct 8, 2002 | 05:19 AM
I30tMikeD's Avatar
The fact that other police officers will give you tickets suprises me. My brother in law is a firefighter, he never gets tickets. Even my siseter gets away because she has a shield on her license plate.
Old Oct 8, 2002 | 07:39 AM
genepool's Avatar
I just wanted to get in on this I30 thread.......
Old Oct 8, 2002 | 04:30 PM
fst96se's Avatar
[Beavis and Butthead voice] huhu....huhuhu...huhu...i30's kick asssss....huhu...huhuhu...huhu...ya....they rule....[/Beavis and Butthead voice]
Old Oct 8, 2002 | 06:03 PM
BBaker025's Avatar
They need to make a "General I30 Disscussion" forum on this site. Ive said this many times, and I believe there are enuff of us I30 owners here to make it happen
Old Oct 8, 2002 | 07:38 PM
I30tMikeD's Avatar
Ditto. We have some pretty nice I30's on this site. BBaker, it looks like your getting a nice list of mods on your car. I think you might be the first I30 to do the VI.
Old Oct 8, 2002 | 08:08 PM
mayhem_J30's Avatar
if i wasn't dumping so much money into my other car i would probably already have it in the mail.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
RinconI30
Nov 10, 2015 10:55 PM
2kmaximel
Sep 10, 2015 08:13 AM
