Supercharger & Fuel Pressure
Peeps running Supercharger & fuel pressure gauge, please help out.
I need to know what
Pulley size:
Boost:
Maximum fuel pressure:
I'm running a SC w/ 3.33 pulley however, I do not have a fuel pressure gauge. I would like to go for the variable intake & assuming that it will add 20-30 wheel hp, I need to know if I need to upgrade fuel injectors.
I consistently see 8psi boost. According to MardiGrasMax 10 psi is the limit for stock fuel injectors. 2 psi = 20-25 whp. MEVI=20-30 whp. Therefore, it is quite possible that I'll max out my injector limits with MEVI.
What fuel pressures do you guys see & at what boost/pulley levels?
Thanks in advance...
I need to know what
Pulley size:
Boost:
Re: Supercharger & Fuel Pressure
I don't believe your theorum of transitivity applies - the MEVI does NOT equal +2lbs of boost. You are effectivly reducing the length of the runners and NOT pumping up the boost. You should be more than fine with the 3.33 and a 8:1 disc. My .02, anyone else?
I need to know what
Pulley size:
Boost:
I need to know what
Pulley size:
Boost:
Re: Re: Supercharger & Fuel Pressure
Yeah, I thought the same at first, but if the MEVI is helping the engine breathe better, then the ECU has to be giving the engine more fuel, too, based on the additional air that the MAF is detecting. So if the fuel pressure is already up to the limit due to boost, then the additional air due to the MEVI will lean out the mixture if additional fuel can't be added. Am I wrong? Where are the experts?
Re: Re: Re: Supercharger & Fuel Pressure
All in all... if you plan on keeping your 3.33 pulley, then get the VI, don't worry about fuel pressure, because the 6:1 has enough fat on the top to burn off... Get it on a dyno and see for yourself. I don't know how people run SC's and stuff, especially bumping down pulley sizes, adding VI's and all this jazz without the right instrumentation at their disposal. Guages are critical. I think any Boosted max planning to go lower than 3.33 (9 psi or so) needs 3 guages. Boost, Fuel Pressure and EGT... others are nice to haves, those 3 IMHO are musts.
Any more thoughts??
Originally posted by Y2KevSE
6:1 should work up to 3.125. 8:1 will actually make you run a little rich with 3.125, but rich is better than lean.
I am leaning towards Stephen Max's hypothesis. The extra air I'm dumping through the MEVI needs the extra fuel. Two possibilities:
(1) The ECU provides the extra fuel based on MAF sensor.
(2) The 6:1 FMU disk provides plenty extra fuel (for safety reasons) to compensate for extra MEVI air.
Unfortunately I do NOT have a fuel pressure gauge. I have EGT, Air/Fuel & Boost. I would like to stay within safe fuel pressure limits. I was told 90 psi is a reasonable limit of our 240cc injectors.
I agree with you Kevin, however, this richnes at very high fuel pressures can cause one or more injectors to sieze up & bye bye engine.
If you're REALLY worried about fuel pressure, stick with the 3.33 (always been in the smallest but safest pulley in my opinion) and don't go any smaller. If the pressure was too great, you would've heard about blown motors by now.
So, to conclude:
3.33" + MEVI = NO Injectors, 8:1 disk.
3.125" ONLY = NO Injectors, 8:1 disk, Blitz BOV.
3.125" + MEVI = Injectors, ??:1 disk, FPR, profe$$sional tuning costs.
2.87" + MEVI = Please stop me from even thinking about it
Hmm... I see your point. The only blown motor I personally know of is BriGuyMax, running over 100 psi fuel pressure & fried piston rings.
So, to conclude:
So, to conclude:
I have to disagree with this..
3.33" + MEVI... Stick to the 6:1... And watch the EGT guage...
3.125" Only... You can probably continue on the 6:1...
3.125 and VI 8:1 for sure, and that is PLENTY of fuel... no real tuning involved
2.87" + MEVI 8:1 should still be plenty... if not, this is the point at which I would seriously consider going the injector route. with the 3:1 FMU disc.
I have run the 10:1 disc, and am not at all hyped up on the thought of running that high fuel pressure. Hence my investement in the below items:
Let the EGT guage be your friend. And let it be your guide to your homebrew tuning. Professional tuning is not always needed.
So, to conclude:
So, to conclude:
3.33" + MEVI = NO Injectors, 6:1 disk.
3.125" ONLY = NO Injectors, 6:1 disk (8 if you want to play safe), Blitz BOV.
3.125" + MEVI = Injectors, 6:1 disk (8 if you want to play safe)
You definitely want to tune after swapping pulleys, but you can't tune unless you have an adjustable FPR or AFC.
Originally posted by delio
Ding ding ding.... We have a winner... BTW Chung, expect a delivery soon buddy
I was thinking about RC Engineering and getting 280-300cc sized ones... about $80 per injector?
Theorum of transitivity
I like that remark made by Confused, "theorm of transitivity". I couldn't resist but research a little more on fuel injectors. Mathematically speaking:
Lets take our stock 240cc/minute injectors & convert to lbs/hr:
To convert cc / min to lbs. / hr. - Divide by 10.5 = 22.86 lbs/hr
Now, using the formula:
lbs/hr = (BHP X BSFC) / (Number of injectors X Duty Cycle)
Assumptions:
BHP = Crank Horsepower assuming 17% drivetrain loss. Therefore, BHP = 1.17 X Wheel HP.
BSFC = 0.53 is a safe, reliable estimate for SC cars. Perfectly stoichiometric.
Duty Cycle: 80% or 0.80 is industry accepted standard.
240cc/minute = 22.86 lbs/hour
Using the Formula:
BHP = (22.86 lbs/hr X 6 injectors X 0.80 duty)/0.53 BSFC
BHP = 220 = 187 wheel hp. This is at a static flow of 43.5 psi.
To obtain 300 wheel hp from 3.125 or smaller pulley:
300 whp = 355 bhp requires
370cc injectors
@80% duty cycle
@53 psi system fuel pressure
Currently, on my stock 240cc injectors, I am pushing things over 85psi fuel pressures to obtain 270 whp.
Does anyone know where I can rent Delta Dash or similar OBD-II diagnostics tool? Would like to measure my duty cycle. I bet it is over the recommended 80% limits...
Assumptions:
Using the Formula:
370cc injectors
@80% duty cycle
300ZX Twin Turbo Comparison
To further backup my findings, I did some digging on 300ZX Twin Turbo upgrade path.
The stock 370cc injectors are okay upto 450 crank HP. After that most tuners recommend 555cc injectors. Why? We'll using the same formula:
Up to 450 bhp at 0.54 BSFC pushing 90 psi fuel pressure at 80% duty cycle requires 370cc injectors.
Any more HP & you will risk running unsafe fuel pressures or duty cycles or both.
Re: 300ZX Twin Turbo Comparison
going to the Z injectors is a good idea, I do know you have to change your FMU disk. Which one I am not sure, you have to ask Matt (Mardigrasmax) or call Vortech and they can help you with that. I am running very rich. At 10 PSI my fuel pressure is 100PSI. That is the reason why I ordered the SAFC. The fuel pressure I got a direct reading straight out of the FMU hose that connects to the top fuel rail, and ghetto rigged it and took it on a spin on the highway. Since you are planning on going w/the smaller pulley dont forget to shave down that plate therefor your belt wont touch. Look below your pulley see that part where one of the bolts go thats the spot you will shave down. Wont take you that long 15mins tops. Also since your doing all these major upgrades hell you need to upgrade that intake to a CAI. Just my opinion. Snow is right around the corner so you can leave that project for March something like that.
Using a Cartech FMU (it does not use disks), my FP is 65-70PSI Max, and I'm tuned on a Dyno to 12.5:1 across the powerband.
I don't think you'll need bigger injectors with a 3.33" Pulley.
At least I don't, but maybe the FP needed is different with a Cartech FMU.
Re: Re: 300ZX Twin Turbo Comparison
100 psi.
I think it is a general consensus among people on this board, 300ZX TT peeps & boosted IS300 folks that 90 psi is reasonable maximum FP. Anything more is pushing things. If you think about it, stock Maxima pushes 43.5 psi fuel pressure at WOT at max horsepower. Essentially what they told me is that you can somewhat safely double this pressure on good quality fuel rails & injectors. They started bragging about how their IS300's are essentially a Supra in sedan's clothings & their **** is better...anyways...
Better get that FP down as soon as possible. To run at 0.50 BSFC mixture, you need no more than 90 psi at 80% duty cycle.
Currently you are at 85% duty cycle on 100 psi.
Fuel Injector Calculator
Re: Re: Re: Re: Supercharger & Fuel Pressure
Originally posted by iansw
I am running a 3.25 and getting 9PSI with the MEVI.
There are three possibilities using pure physics & mathematics:
(1) Your FP gauge is off by 10psi.
(2) You're not running 12.5:1, but actually running slightly on the lean side.
(3) Your injector duty cycle is exceeding the safe 80% limits.
Of course, my math could be wrong. Find out for yourself:
Fuel Injector calculator
Re: Re: Re: Re: Re: Supercharger & Fuel Pressure
To obtain 267 fwhp = 310 bhp on 240cc injectors @ 80% duty cycle, and 0.48 BSFC (pretty much stoichiometric, but a tad bit on the lean side) you need 80 psi fuel pressure.
Without the MEVI, I'm only 231hp.
IanS
Without the MEVI, I'm only 231hp. I don't believe the MEVI changes FP.
IanS
Re: Re: Re: Re: Re: Re: Supercharger & Fuel Pressure
No, it's probably the MEVI that's it.
IanS
IanS
(9psi X 6) + 43.5 psi = 97.5 psi fuel pressure.
Since you're only seeing 70 psi, something (either a smaller FMU disk or AFC) is leaning out the fuel pressure.
Re: Re: Re: Re: Re: Re: Re: Supercharger & Fuel Pressure
Well, the fuel pressure is regulated by the Vortech FMU. Assuming that you are running the 6:1 disk and your boost gauge is registering 9 psi boost, then essentially your fuel pressure should be:
I know I tuned ito n the Dyno. 12.5:1 across the band.
IanS
Re: Re: Re: Re: Re: Re: Re: Re: Supercharger & Fuel Pressure
I don't have a Vortech FMU, I have a Cartech FMU.
IanS
IanS
[(9 psi) X (6 from FMU disc)] + [(36psi base pressure) / 2] = 72 psi
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Supercharger & Fuel Pressure
34... 36... close enough (FSM).
I believe you, however, your 5th gen stuff might be slightly different. Do you have 4th gen FSM?
From what I was told the 4th gen 240cc injectors are rated at 43.5 psi max. fuel pressure. This is at WOT (zero vaccumm/atmospheric pressure).
At idle (full vaccumm) the fuel pressure should be:
43.5 - 14.7 atm. press. = 28.8 psi.
If only I had a freaking fuel pressure gauge...
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Supercharger & Fuel Pressure
Now THAT I did NOT know...
Duty Cycle
I was at 100% duty cycle at ~5750rpms when I was running a 3.125 pulley with the MEVI on stock 240cc injectors. I could see the change in the O2 graph on my dyno plot becaue I would start lean out even with an 8:1 from ~5700rpms up and the Fields AFC adjustments had no effect. IMHO the stock MAF is only good to ~300bhp
Re: Duty Cycle
And what is this about MAF choking on us?!?!?!
Will we need a different MAF sensor? or worse a bigger throttle body??
I'm definitely making more than 300 bhp with my setup on stock MAF...
Re: Duty Cycle
http://boostedmaximas.com/jane97se/i...ynos/dyno5.jpg
Re: Re: Duty Cycle
Were you leaner than this?
FWIW the car ran fine though, no detonation that I or the dyno operator coud detect.
Re: Re: Re: Duty Cycle
Yea, IIRC ~13.5:1 at 6300rpms when the dyno operator cut it off.
Jane's 8:1 without Cartech:
http://boostedmaximas.com/jane97se/i...ynos/dyno3.jpg
