ATTN people with upgraded headlight wire harness.. do your high beams work?
Old Oct 8, 2002 | 08:27 PM
NYCe MaXiMa's Avatar
I had APC headlight harness for 100/80W bulbs but, when I turned on the high beams, only 1 headlight worked and i'm not even sure if it flipped to the high beam or not...
Anyone else had this problem?
What kind of headlight harness are you running?
Old Oct 8, 2002 | 08:30 PM
hockeyghst's Avatar
Re: ATTN people with upgraded headlight wire harness.. do your high beams work?
i knwo edactly what ur talkign bout....but wiht my harness when i put my brights on tehy both work...sometimes my brights work and somtimes i have to flip the brights on off for them to kick on at night....its weird....
Old Oct 9, 2002 | 01:19 PM
Re: Re: ATTN people with upgraded headlight wire harness.. do your high beams work?
yeah
thing is,
mine just had 1 headlight working with the high beams, no matter how much you messed with the wires and the switch.. i think it was because of the design and installation process of those wires.. you plug one stock connector to the aftermarket harness and just leave the 2nd connector hanging in the engine bay and tape it up with electrical tape.. that is how they were supposed to be installed
i didn't know this for a very long time becuase i never used my high beams since i live in NYC.
Anyone else with upgraded harness? how do your high beams work?
Old Oct 9, 2002 | 01:59 PM
JDM4LIFE's Avatar
i had the same problem, i have no idea why, but when i would move around the two small black boxes, they would come on, so i just kept messing around with different positions to sit them in to keep them on and left it there. kinda shady and weird way of doin it, but that's the only way i got them to work
Old Oct 9, 2002 | 02:04 PM
Tifosi's Avatar
I have APC harness as well, no problem with high beams what-so-ever! If you have to move the box to get both your high beams working, one of your relays might have gone bad.
And yes, you only use the drive side stock connector and leave the passanger side unplugged.
Tifosi
Old Oct 9, 2002 | 02:52 PM
Gotrice4's Avatar
mine work absolutely fine, both low and high beams, but my headlights sucks(that's another story)...but you use only one headlight connection because you are using the relays on the new harness not the stock ones. So that is how it is suppose to be installed....
Old Oct 9, 2002 | 02:58 PM
SpeedCrazie's Avatar
I have upgraded harnesses also, but no problems here (Knock on Wood)I got the Nokya harness and have run them for about 6-7 months.
~SpeedCraize
Old Oct 9, 2002 | 04:05 PM
athlon omega's Avatar
~SpeedCraize
LOL. I had the APC wire harnesses for about two months; then I got rid of them. I noticed after about a month, the driver's side light would become considerably dimmer than the passenger side light. When I jiggled the connectors, the lights would be fine. A month later I noticed that the problem was back, and it was due to the black wire on the driver side melting! I called up a local import store and found out about the Nokya wire harnesses. It basically replaces that stock harness. The hardest part was trying to match up the wires correctly. It took me a 3 hours! I was doing it by trial and error. However, they been wroking fine ever since and only cost me $13 compared to the $54 for the that tangled mess of APC wire harnesses I bought from Nopi.
Old Oct 10, 2002 | 05:20 AM
ThurzNite's Avatar
Where did you buy the nokya upgraded wire harness?
what bulbs do y'all run? I don't remember nokya carrying bulbs that don't run on stock voltage. I know they have fake ones that run stock voltage and look like 100/80. Piaa doesn't have any either.
Jae
Old Oct 10, 2002 | 05:38 AM
PBeachMax's Avatar
Last night I started having a problem with my APC wire harness. My driver side was way dimmer than my passenger side. I also lost my high beams. So far I found the relay went bad, that explains my high beams not working. I going to check the black wire as athlon omega did to see if that is the case with my light being dim.
Old Oct 10, 2002 | 08:38 AM
JAY25's Avatar
Check your ground on the side that is not working. I had the same problem but got it fixed.
Old Oct 10, 2002 | 10:14 AM
PBeachMax's Avatar
Thanks, I will check it.
Old Oct 10, 2002 | 12:54 PM
thanks for the replies...
I had problems with one of my headlights going dim numerous times.. I had to jiggle the connectors and the ground wires..
Then I found corrosion in the actual plug...
APC harness seems to be problematic..
Anyone looking for the Nokya upgraded harness, go to www.southwestautoworks.com it's like 15$ there!
I'm going to order this as well..
which brings me to my next question.......
This is getting a little off topic
but...
what bulbs are you guys with upgraded harness running in your headlights?
I need a nice WHITE (no yellow, as little blue as possible) bulb 100/80W
Old Oct 10, 2002 | 01:29 PM
Tifosi's Avatar
but...
I'm just using APC xenon white 100/80 bulbs. I saw a comparison with them and Piaa in person, don't see why I had to pay more for Piaa's, plus when I got all my bulbs from Baxter Auto, all APC bulbs carry a lifetime guarrantee. As a matter of fact, all APC electrical stuff has a lifetime guarrantee, including my wire harness. So that's why I didn't go with Piaa's or any other brand.
Tifosi
Old Oct 11, 2002 | 11:35 AM
I picked up my Nokya harnesses at a local performace shop. I have spent so much money on bulbs. 3 ($60-75 total) pairs of Nokya Artic Whites (I should of only needed two, din't know my harness was bad) 1 ($25 a Piece) pair of Sylvannia SilverStars, and currently a pair of PIAA's.
~SpeedCrazie
Old Oct 11, 2002 | 10:35 PM
The bulbs that I currently run are Xenon FX 5000K. These bulbs are very bright and emit a nice white light with a slight hint of blue. I got them off of ebay and have had them since March with no problems. They have new ones called the XD5 5100K 80/100W bulbs that emit pure white light! I'm thinking about getting those and using my current ones for spares.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1865806860
jerrod99_se-l
Aug 27, 2015 08:27 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
kenc15
Aug 5, 2015 08:29 AM
