click clack click clack click click
Old Oct 9, 2002 | 10:36 PM
cocolopez's Avatar
hey i have a 95 max se with about 146k mi. and my engine is really noisy. my friend's 96 max's engine is real quiet like (with hood open) i mean not completely quiet, but you know, nice engine quiet (i dunno, humor me).
my engine sounds like a click clack clack clack click clack clack noise... what things should i be looking for?
i got my wrench, my hammer, hot glue gun, and im ready to start bashing stuff up!
Old Oct 9, 2002 | 11:00 PM
Brendan's Avatar
yeah find the ecu, the spark plugs and the air box, and beat the he11 out of them with the hammer, that usually works. If its a clicking, find out around what area its coming from and let us know, or go to a mechainc, they usualy won't charge you just to listen and take a quick look. Goodluck
Old Oct 9, 2002 | 11:36 PM
RodolfoGraziani
Re: click clack click clack click click
Your car probably sound like my bro's 300ZX before he got everything fixed.
Oh boy, it requires opening of the engine, so I say go to mechanics and have some things readjusted and replaced.
It's gonna run somewhere $500. But of course, I could be wrong, and it could be as simple as a loose nut or bolt
Old Oct 9, 2002 | 11:45 PM
MaxJag's Avatar
Mate,
It could be the valves.
Some cars need the valves adjusted to the correct clearances.
My Jaguar had the same noise.
I fixed it by replacing the shims on the valves.
I'm not sure if the Maxima has shims.
Just a thought.
Cheers!
Old Oct 10, 2002 | 05:17 AM
Lime's Avatar
that sounds like valve chatter, but with that many miles on the car, it could also be excessive carbonization of the pistons.
Old Oct 10, 2002 | 06:57 AM
njmaxseltd's Avatar
If it is your valves, then you've got some excessive engine ware going on. Our VQ motors do use a bucket and shim setup. This setup usually requires little or no maintenance over the life of the car. It's possible that your cam shaft or shims have worn a bit causing excessive valve lash. It can be adjusted, it's not an easy job. Special tools are required to remove the shims and I'm sure your local mechanic isn't going to have the Nissan specific tool for this job. Take your car to Nissan and see if indeed your valves are the cause of your noise. If so, I'd let them do the adjustment.
Tom
jmlee44
Oct 2, 2022 02:13 PM
mclasser
Sep 24, 2015 11:57 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
ajahearn
Sep 19, 2015 03:03 PM
bennuss
Sep 11, 2015 05:55 AM
