99 SE ECU in 98 GXE?
Old Oct 12, 2002 | 11:10 AM
SlavDaddy's Avatar
Don't trust me, I'm sneaky
Okay, so I found a 99 SE in a junk yard, and I have two questions about it.
1) Do SE ECUs have a speed limiter?
2) Will a 99 SE ECU work in a 98 GLE if they are both autos? I don't want to switch out wiring harnesses or anything, I just wanna unplug and plug.
Can I do that stuff?
Thanks.
Old Oct 12, 2002 | 11:13 AM
mzmtg's Avatar
Minister of Silly Walks
No, it wont have a speed limiter.
No, it wont work in your car. Well, it will work, but you may get a constant Check Engine light.
Old Oct 12, 2002 | 03:06 PM
Nismo3112's Avatar
Custom User Title
SE's have no speed limiter eh? My 99 SE-L can only hit 115
Old Oct 12, 2002 | 03:58 PM
mzmtg's Avatar
Well, then it has problems...
Old Oct 12, 2002 | 04:33 PM
Sprint's Avatar
keep pushing the pedal
Old Oct 12, 2002 | 04:37 PM
Nismo3112's Avatar
Custom User Title
::All the way down..once it reaches 115 @ 6500rpm it jumps to 5k rpm as i slow back down..
Old Oct 12, 2002 | 04:40 PM
Sprint's Avatar
are you working that OD button? maybe something is wrong with your tranny that its not shifting to 4th... because on a limiter.. the gas cuts till it reaches back to 100 mph.. you can press the gas all you want to and move the rpm's up.. but the car gets no power
Old Oct 12, 2002 | 06:23 PM
Nismo3112's Avatar
Custom User Title
my 4th gear works like a charm..70 mph @ 2400 rpm sounds about normal right? I know it works cuz when i push the OD button the rpm's jump (3rd gear)
Old Oct 14, 2002 | 04:00 PM
SlavDaddy's Avatar
Another Shot
So what if I found another 98 SE ECU, would that still give me check engine lights?
Old Oct 14, 2002 | 04:43 PM
Jamsan's Avatar
just remove the limiter from your GXE
about your 99 SE-L with limiter....i originally thought i had a limiter on my 97 se.....and i would be approaching 115ish, and the tranny would shift, down to about 4.5k rpm, and it wouldnt go any higher...i thought that was the limiter kicking in, but it was the tranny shifting....so a few thinigs i did was TB cleaning, changed the fuel filter...a.fter that i could hit ~135ish, but it would take a while to get up there....after having my Y installed last week, 130 comes like nothing
Old Oct 14, 2002 | 05:17 PM
SlavDaddy's Avatar
Removing speed limiter
Won't removing the speed limiter make the check engine light come on? I am just paranoid about making the light come on - what if something goes wrong and I don't catch it until it is mad expensive to fix because my light is always on? Am I just a panzy?
Old Oct 14, 2002 | 05:19 PM
Jamsan's Avatar
Am i just a panzy?
yes you are
...seriously, look for ben's ecu mod, yes it will make a CEL trip, but what you can do is, if your savy enuff, wire a switch to it, so that you flip it when you wanna go 130, and then unflip it when you want the CEL off...youll have to reset the ECU after you flip the switch off, but it will go off....does that make sense?
Old Oct 14, 2002 | 10:00 PM
SlavDaddy's Avatar
Hey, good plan
I like that idea. It gives me something to think about. That was damn igenuitive!
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
