Tune Up tools
Old Oct 12, 2002 | 04:03 PM
gambit's Avatar
Tune Up tools
I recently bought a Maxima and it had close to 90k miles on it. My dad would like me to perform the tune up myself so....
What tools do I need to perform a tune up at 90k miles? I have the Nissan maintenance manual but there is no tool list in the MA section. Also, how do I flush fluids? Is there anything else I should know for a beginner?
-Gambit
PS: What's the most gas efficient RPM?
Old Oct 12, 2002 | 04:13 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Tune Up tools
Zero.
Old Oct 12, 2002 | 09:42 PM
SuDZ's Avatar
Re: Tune Up tools
-Gambit
Basic wrech and ratchet sets. Maybe a scredriver or so.
SuDZ
Old Oct 12, 2002 | 09:59 PM
joaquink's Avatar
¿Hablas Español?
Re: Tune Up tools
-Gambit
Gambit - welcome to the Maxima community. You'll need a spark plug
socket for the plugs and other than that just basic socket set,
pliers and a screwdriver. The latter two items will help out when
you change the fuel filter. For good info and details on how and
what to do go here: MaximaDriver.com
Just click on HOW2 in the left pane and select your activity from
the links on the right. Probably worthwhile to start with the 60K
tuneup section.
Cheers,
JK
Old Oct 12, 2002 | 10:29 PM
iansw's Avatar
Don't forget to buy a Panel-Popping tool.
It's a godsend to get fuel lines/vacuum hoses/any other small hose off.
Old Oct 12, 2002 | 10:54 PM
gambit's Avatar
Thanks for all your replies. Btw, what does a panel popping tool look like?
-gambit
Old Oct 12, 2002 | 11:01 PM
iansw's Avatar
-gambit
It looks like a small crowbar with a screwdriver type handle. You can walk into any Auto parts store and say "I need a panel-popper", and they'll know what to give you.
You simply wedge the crowbar end between the hose and the piping it's attached to, and pry the hose off. it works perfectly, and also keeps you from accidentally ripping a hose from pulling on it.
IanS
Old Oct 12, 2002 | 11:23 PM
Requin6's Avatar
-gambit
here is a pic of mine...
i think it was like $5 from crutchfield.
Old Oct 12, 2002 | 11:39 PM
JPMax's Avatar
What's next!?..
Other tools you may need:
A 10" extension for the rachet set:
Helps out in lots of hard to reach places. Including replacing spark plugs.
A Torque wrench: For tightening all those bolts to Spec
A Breaker bar: For loosening all those old rusted stock bolts that won't move with the normal rachet. (ie. Struts, Starter..)
Have fun.
Old Oct 13, 2002 | 01:48 AM
Nismo's Avatar
anyone mention floorjack/stands?
Old Oct 13, 2002 | 04:30 PM
JPMax's Avatar
What's next!?..
Oh yea.. a floor jack and stands!
Maybe a set of ramps too.
Old Oct 13, 2002 | 05:15 PM
gambit's Avatar
You guys are the greatest, thanks a bunch.
Old Oct 13, 2002 | 06:05 PM
gepetto's Avatar
If I may add my suggestions (from experience):
ViseGrips - gets off what won't come off otherwise. Often, you'll have to replace the bolt, but if somethin is broken, you need it fixed.
A lot of common sense - taking stuff apart/putting it back together is not too tough, as long as you think it through.
The search function - if you haven't discovered it already, its at the top right and will SAVE you so many times.
If all else fails:
http://forums.maxima.org ... but you already found that!
Old Oct 19, 2002 | 01:18 PM
gambit's Avatar
I've been looking everywhere and I can't find a panel popper. I've checked Sears, Kragen, Autozone, and Pep Boys. I live in Orange County, CA. If anyone knows a place where I can purchase a panel popper, it'd be greatly appreciated.
-gambit
Old Oct 19, 2002 | 05:49 PM
henock
Re: Re: Tune Up tools
Originally posted by mzmtg
Zero.
Old Oct 19, 2002 | 06:19 PM
hbsprite's Avatar
did you actually "ask" for the panel popper? Or did you just look for it? They may have it behind the counter.
Old Oct 19, 2002 | 10:25 PM
gambit's Avatar
I asked.
-gambit
Old Oct 19, 2002 | 10:41 PM
iansw's Avatar
Go to a car stereo shop and ask them where they get theirs. They can likely order one for you, or tell you where to go.
IanS
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Socalstillen
Sep 26, 2015 12:01 PM
Maxboy23
Sep 4, 2015 06:04 PM
