installing gen 1 coilovers
Old Oct 17, 2002 | 01:44 PM
hockeyghst's Avatar
ok i knwo how to do suspension installs but this is my only problem with these coilvoers.....i can not get the middle bolt off of the top of the strut....as i turn the bolt to loosen it the entire shaft spins.....with my other suspension installs i never had tthis problem because it was much easier to get that bolt off.....any suggestions???thanx
Old Oct 17, 2002 | 01:57 PM
BC_95GLE's Avatar
Re: installing gen 1 coilovers
what i do to break the bolt loose is not the best but it has worked to me many times. Place the upper part of the coilover in a vice. dont tighten it to much cause it will bend but just enough to loosen the bolt, it should work. What are you doing with you air-ride suspension? was that hard to instal cause i would like to get one. Brian
Old Oct 17, 2002 | 02:01 PM
hockeyghst's Avatar
Re: Re: installing gen 1 coilovers
i dont have a vice.....i am jsut taking the air ride off for the winter just cuz i dont feel like messing wiht a busted line or somethign liek that in below zero weather/snow.......
Matt93SE
May 24, 2019 02:58 PM
zdreamz32
Dec 13, 2015 09:40 PM
