MAJOR oil leak... oil pressure sender unit?
Old Oct 17, 2002 | 03:43 PM
nadir_s's Avatar
vicodin ... gift of life
Hi guys, omg i've come across my first problem on my maxima. Actually i found out 2 of em today.... but this one requires more immediate attention. The oil is leaking steadily and since i noticed it JUST today i think i may be low on oil. I visited my cousin who used to drive the car and we just noticed that its leaking pretty bad underneath. I have searched and read the FAQ's about the Oil Pressure Sender unit which is known for going bad.. i'm hoping it's just that. The thing is.. where is this located?? The leak is in front of the driver seat area... like about the area where the tranny fill bolt is i think. I was going to get it checked out today but i'm afraid of the mechanics bs-ing me about something else that could cost alot of $$$ cuz the car has 140k miles on it. Thanks for ure help!
Old Oct 17, 2002 | 03:48 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Re: MAJOR oil leak... oil pressure sender unit?
If that indeed is the origin of the leak, you have a major problem. See a mechanic you trust.
Search for "OPS replacement" in the 4th gen forum to see the procedure involved.
Old Oct 17, 2002 | 04:31 PM
97MaximaSE's Avatar
mine is leaking too but my mechanic who works at a nissan dealership said it was no problem....he said they all do it at one time or another and that they usually dont leak enough to be noticable
Old Oct 17, 2002 | 04:51 PM
nadir_s's Avatar
Re: Re: MAJOR oil leak... oil pressure sender unit?
ah damn but the prob is i don't know if it's the oil pressure sender or not lol.
It leaks quite a bit for me... and after a while when the car stops, it kinda goes away... but then again this probably with all oil leaks. I just hope it's not a gasket or something.
Old Oct 17, 2002 | 05:04 PM
karguy's Avatar
I believe the oil sender is on the back of the engine near the oil filter. Your leak is on wrong side of the car! Time to get a mechanic you trust to look at it! Sorry
Old Oct 17, 2002 | 05:05 PM
nadir_s's Avatar
noooooooooooooooooooooooooooooooooooooooooooooo
thanks tho
anyone have any idea what it could be? My cousin suggested a gasket.... but he said that costs major $$...
Old Oct 17, 2002 | 05:14 PM
Mishmosh's Avatar
Make sure it is motor oil and not tranny oil. Check the level of your tranny oil. Maybe just a gasket and hopefully not worse than that. You may want to jack up the front end, put it on jack stands, and go in for a better look to pinpoint the problem. I tend not to trust repair shops so find out as much as you can of the problem/source before resigning yourself to a professional.
Old Oct 17, 2002 | 05:17 PM
nadir_s's Avatar
It's motor oil. My cousin and his friend said it could probably be a gasket... what are gaskets?? They said it could cost major $$ cuz the mechanic would have to take out the lower half of the engine block... any thoughts guys?
Old Oct 17, 2002 | 05:28 PM
iwannabmw's Avatar
Are you sure it's motor oil and not gear oil. Based on your other post, that sound you described could very well be the diffential bearings and if so that would explain a leak in that area perfectly. It would be pretty hard for motor oil to leak in that area without completely coating the tranny as well.
Old Oct 17, 2002 | 05:45 PM
Kashoggio's Avatar
the oil pressure sending unit is right behind the drain plug, its on the oil pan itself. Not a big problem changing it. AS it goes for the otehr leak it also could be a bad Cv boot just get under the car and start poking around
Old Oct 17, 2002 | 05:59 PM
nadir_s's Avatar
I don't know if this helps or not.... but check out the pics i took:
http://snow.prohosting.com/nprimex1/oil_leak/
You know what, I'm not 100% sure it's motor oil... i don't know what gear oil looks or smells like so it could be that too. But i'm pretty sure it is motor oil because it smells like it.
BTW- the sound that i had has been there for a while, except today i really pushed the car when driving to exactly make out that sound w/ my cousin... possibly that screwed it even more?
Old Oct 17, 2002 | 06:54 PM
nadir_s's Avatar
ah help me! i'm goin nuts, it's still dripping! and I'm sure it's motor oil. I put it on my finger and it has a yellow-ish tint to it.
Old Oct 17, 2002 | 07:13 PM
190hpKiLLA's Avatar
Granny Driven
My oil pressure sensor used to leak but i fixed it for like 40$ bucks. No probles so far.
Old Oct 17, 2002 | 07:20 PM
Mishmosh's Avatar
Dude, the picture quality sucks but I'm almost certain you are leaking gear/tranny oil. Do not drive the vehicle and check to make sure the tranny oil is not fully depleted. Some of the side pics show, from what I can tell, an area right where the transmission drain bolt is located. No way motor oil gets that far to the drivers side of the car.
If you do get tranny oil to refill it, get GL-4 tranny oil. Again, I hope it is some gasket that needs replacing vs. bearing or transmission failure.
Old Oct 17, 2002 | 07:29 PM
Mishmosh's Avatar
It is definitely NOT the OPS. Usually that leaks very very slowly and is on the opposite side of the car. A second look at your pics shows the leak to be on the outside of the where the shifter linkage is. Definitely transmission territory.
With 140k, did you have a new clutch put in recently? Did you have a mechanic service your car recently?--I wouldn't even exclude sabotage... I have heard of CV boots being thrashed shortly after a trip to the mechanic, if you know what I mean...
Old Oct 17, 2002 | 08:16 PM
nadir_s's Avatar
Sorry for the crap pics... the camera sucks.
BUT YES, you guys are right. What i did was i took some kitchen towel paper and used motor oil from the dipstick to seep and absorb in the tissue then i absorbed the leaking oil and compared...
The motor oil was a more dark brownish yellow color and the leaking oil was more clear and almost like water... then i smelled both of em, motor oil had that sweet kinda smell whereas the tranny oil stank bad. So definately it's not the same oil... and it is leaking from the transmission area... which is probably even more bad. Could it be a gasket in the transmission? blah! this sucks, it's probably gonna cost and assload now. anyone had this leaking problem?
BTW- i'm not sure, is there a dipstick for the tranny oil in a 5-spd? If not, how do i check to see if i have enough to drive about 6 miles to the mechanic....
Old Oct 17, 2002 | 09:02 PM
iwannabmw's Avatar
Gear oil smells very bad and will stay a yellowish color much longer than motor oil. Motor oil darkens up pretty much after the first start, gear oil will stay yellowish for mulitple thousands of miles.
There is no dipstick for the 5 speed. The tranny is filled properly when the level is at the bottom of the fill plug hole. You'll have to remove that using a 1/2 socket drive and stick your finger in there. If you can feel fluid your good.
Old Oct 17, 2002 | 09:07 PM
nadir_s's Avatar
dang, alright then it's definately tranny oil. I don't get how this occured... it happened all today. It wasn't leaking yesterday because i checked my garage and didn't see any oil at all.
This is not cool... do you guys think this problem may be somehow related to the weird sound my car makes when i accelerate (kinda like a whining sound... "whaaaaa-whaaa-whaa-wha" gets faster as i accelerates) Ben said it was probably differential bearing... but then again i've had this problem before the leak. ARGH!!!!!!
anyone have any experience w/ some sort of tranny leak??
Old Oct 18, 2002 | 05:58 AM
iwannabmw's Avatar
It could be related. If it is the bearings, it would describe the problem perfectly. The bearings can begin to fail and make noise for a long time before they will be worn enough to cause a leak. If the whine is at a constant volume and increases in pitch as the car accelerates through first gear, then starts over again and increases in pitch through second, this is normal and not a problem. It took me a long time to realize the tranny sounds like that. If the sound increases and decreases in volume in a rythmic fashion, the bearings could be the culprit.
If you look at the point where the axle goes into the transmission and find a leak there and play in the driveshaft it is most likely a bearing problem. Another common leak on this transmission is the big black switch located towards the drivers side on the lower half of the transmission. This is an easy fix. Internal seal leaks aren't that common but certainly are possible.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
foodmanry
Sep 24, 2015 12:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
