URGENT: Am I cali or FED spec???
Old Oct 18, 2002 | 06:25 AM
shaz's Avatar
OK in the FAQ it says that on the VIN plate under the hood...the 12th character in the BLHUL series of numbers is the destination...V being CALI...well mine has a V so I'm cali spec. But then that picture from custommaxima.com that shows the engine bay and how to check based on the O2 sensors...if you have 2 O2 sensors you have FED spec...I have 2 up front there...so am I cali or FED??? wtf? I have a 98 GXE...I live in CT but bought used...I guess it could have come from somewhere else...thanks
shaz
Old Oct 18, 2002 | 06:55 AM
Jamsan's Avatar
fed
Old Oct 18, 2002 | 06:59 AM
shaz's Avatar
Originally posted by Jamsan
fed
thats what i thought. thanks
shaz
Old Oct 18, 2002 | 07:05 AM
Sprint's Avatar
woah woah woah woah.. Cali Spec's have 2 02 sensors up front.. and 2 in the rear..
how to check for sure? climb under the car.. look at the y pipe.. if it has 2 connections for the front bank.. its Cali Spec.. if its just one long pipe coming down from the header.. its Fed Spec..
another way to check is open your hood.. and if you see 4 electronic connectors up front.. its Cali Spec
Old Oct 18, 2002 | 07:07 AM
Sprint's Avatar
you see these 4 connectors up by the radiator? that proves if you are cali spec or not
Old Oct 18, 2002 | 07:09 AM
shaz's Avatar
yeah thats what i meant...the 4 sensors under the hood up front...I only have 2, so I assume I'm FED...Also I read some other posts and I'm pretty damn sure that 96-98's have the same y-pipe no matter what...that you only have to check for 99+ (as far as purchasing a y-pipe is concerned).
shaz
Old Oct 18, 2002 | 07:12 AM
Sprint's Avatar
shaz
or if you buy a stillen it comes as two.. that car above was a 99 btw..
Old Oct 18, 2002 | 07:17 AM
redmaxpa007's Avatar
i SeE what you did therE
yes you are fed.
Old Oct 18, 2002 | 07:19 AM
Sprint's Avatar
Originally posted by redmaxpa007
yes you are fed.
Old Oct 18, 2002 | 07:25 AM
Originally posted by SprintMax
damn i been waitin to use that one..
Old Oct 18, 2002 | 07:30 AM
Sprint's Avatar
Old Oct 18, 2002 | 07:31 AM
tank you..
Old Oct 18, 2002 | 07:33 AM
Sprint's Avatar
tank you..
Old Oct 18, 2002 | 03:54 PM
hbsprite's Avatar
Is the only difference between CALI and FED spec maximas the 4 O2 sensors? How does performance compare between CALI and FED spec Maximas?
Old Oct 18, 2002 | 05:11 PM
Sprint's Avatar
supposedly they are a tad bit slower due to stricker emmisions
jmlee44
Oct 2, 2022 02:13 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
Samedi
Sep 3, 2015 01:07 PM
