another completed B&G/AGX install...pics
i finished my B&G/AGX install last week...weather finally cleared up so i could take some pictures. figured it would be good reference for others considering this setup.
the ride is very nice...not rough at all when the AGX's are set at 2-4. and handles like a car on rails at 4-8. i also did the assembly isolator gaskets, radio shack wire wrap and KYB dust boots. no noise to speak of.
let me know what you guys think.
--Paul
--Paul
Originally posted by gtr_rider
How low does it take your car when settled, it looks close to Sprints. How much for the whole setup, if you dont mind. I can live with that stance..
i got the srpings from www.shox.com at $187 shipped with the .org discount. ($157 before shipping). and i got the AGX's w/boots from www.cattman.com for $455 shipped. spiral wrap = $2, gasket material = $5...total was around $650. rides like a champ though. i think the money was well spent to do it right.
--yeah the wheels are silver...were you thinking they were white? some others have mentioned that to me. they are the '00 SE 16" wheels. i wax them and they are clean i guess they can be mistaken for white.
--Paul
Originally posted by Requin6
i am not sure if the springs are totally settled..i have had them on for a week...but there is a 2" gap all the way around (3 fingers). me and ericdwong were comparing the rear yesterday and his rear 1 coil cut sprints are exactly the same as my rear B&G. his front is lower though.
--Paul
--Paul
Looks good. When I need an alignment again I may try the spiral wrap since I have noise from the front end. I find that for the nicest ride 1/2 works the best, but I usually run 2/2 so the front end feels moderately firm. In any case if you think it's too firm try dialing down the rears.
-hype
-hype
Originally posted by Dev
off topic (sorry) but is the blue popcharger by JWT? or is it the grey one?
cause mine used to be blue and now its fading to grey.
what should i clean it with to keep it blue?
they all turn grey. mine was blue when i bought it, but the blue faded. its sprayed with blue oil and when that goes so does the blue appearance. when you clean your fliter using K&N's kit...it will be red because the oil spray has red dye in it so you can see the areas you have sprayed.
I have the exact same setup as you, wire wrap and all, and mine still makes noises over bumps
Originally posted by spiff56747
Hey did u cut the bumpstops on your suspension at all?
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
