Lower Control Arm Problem
Old Oct 20, 2002 | 08:43 PM
MaxEffect414's Avatar
I took the car to nissan and they told me that i need a new lower control arm cause the one i have is broken.
Now i drive the car everday and i don't think i would be able to drive it and hit 130 in it if it was broken.
What's up with that, Is it broken or just in need of bushings and if so they wanna charge me 640 for two new ones, there's gotta be a better way to get them cheaper... Any ideas???
Old Oct 20, 2002 | 09:00 PM
dmBK's Avatar
How 'bout them cliffs?
Re: Lower Control Arm Problem
i replaced both my lower control arms @130 for each plus labor.
Old Oct 20, 2002 | 09:21 PM
RodolfoGraziani
err
what's the mileage on your max?
If bushings rot off and you drive around, the control arms can get damaged.
but usually it's the bushings only. In that case, ditch rubber and get polyurethane ones from energy suspension. Ride quality is not superior to rubber ones, but they last way longer than rubber.
Old Oct 21, 2002 | 09:48 AM
maxperformance's Avatar
Control Arm
MaxEffect414, Is your tire bending out away from the car or is it leaning in, in some sort of a way. I hit a curb so when my control arm went out, the tire was bending out away from the car, and the tire wasnt centered in the wheel well. Just my 2 cents. Hope it helps.
Old Oct 21, 2002 | 01:46 PM
Thanks alot and no the tire is just fine, I think it's the bushings because i hit 130 with no problem and the mileage on my 99 max is 97,000 lol I know i know
I will check it out and where did you go to get it for 130 plus labor just in case, Thanks.....
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Sep 22, 2015 04:22 PM
intimidator
Sep 5, 2015 07:23 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
