Those with the EGT gauge
Old Oct 22, 2002 | 07:35 AM
XXXL Cracker's Avatar
Did you have a fitting welded into the Y pipe for the sensor to screw into?
If not, how do you have your sensor set up to read the temp of exhaust gases? Where is it mounted?
I was planning on having apice welded in for the fitting however, I am not sure of the best place to place it to get the most accurate reading.
Please advise!
D
Old Oct 22, 2002 | 07:41 AM
Aaron's Avatar
Langley AFB Sux
Re: Those with the EGT gauge
Please advise!
D
I dont have one (yet )
But from what i was told...have a bung welded into your ypipe.....
I think as close as you can to where it bolts up......
Aaron
Old Oct 22, 2002 | 07:50 AM
Re: Re: Those with the EGT gauge
Aaron
I do not think this will give you an accurate reading though. How do you capture the front and rear bank exhaust temp?
I will be usning this with juice so I will need an accurate reading........ I do not want to go Kaboom.
Old Oct 22, 2002 | 08:07 AM
ejj's Avatar
ejj
I don't have the "screw in" type probe, I have a tapered one. So, I drilled a 1/4" hole in the pipe and put the probe in. The probe has a huge hose clamp on it, which you then tighten as much as you can. The force of the clamp combined with the taper of the probe make it air tight. Works great, no leaks.
I put mine as close to the top of the Y-Pipe on the front (left) bank as I could. Idealy you put it in the header.
You don't want it back between the two, because you will get lower readings than you should. If you really want to monitor both banks, you'll need to get 2 guages.
Old Oct 22, 2002 | 08:19 AM
That helps. I do have the option of a screw in or a tapered sensor. I would imagine the taper is easier to do.
What readings have you been getting on and off the juice? You just set this up recently correct?
Dave
Old Oct 22, 2002 | 08:22 AM
ejj's Avatar
ejj
Dave
Yes, the tapered is much easier...doesn't require any welding and is 100% DIY. However, it may affect the re-sale value of your Y-Pipe, but I didn't care about that.
Off the juice I get around 1450F or 1500F in about a quarter mile WOT. I just installed the NOS yesterday, and its way too rich, and I'm getting about 1200F. I'll fix that later today thought.
Old Oct 22, 2002 | 08:54 AM
matt calder's Avatar
Yeah mine is tapered as well. But I put mine in the rear bank y-pipe close to the O2 sensor. The ideal setup would be to have an EGT gauge for each bank. A good A/F ratio gauge would work well too.
Old Oct 22, 2002 | 09:01 AM
Are you running an upgraded fuel pump or stock?
Old Oct 22, 2002 | 09:28 AM
ejj's Avatar
ejj
Upgraded. Walbro and a Sard FPR. NA fuel pressure is great, but I have to get it down when on the bottle.
Old Oct 22, 2002 | 09:36 AM
JAIMECBR900's Avatar
I haven't experienced this first hand but I've been told that the strapped probes tend to work their way loose and leak over time. Mine is thru a bung that's welded on the Y.
You need to have a database of what your car does N/A and then compare that to readings when on the juice. Ideally the readings should not be any more than 50-100 deg F apart during hard runs.
Old Oct 24, 2002 | 03:34 AM
JDM4LIFE's Avatar
okay, i just got a gauge pod too (and am setting up for some go-juice). just outta curiousity, has anyone on here got an egt gauge for front and rear bank? i figured it'd be a nicer way to narrow down a cylinder that's misfiring, etc... or am i wrong? also, trying to judge from what i've read in this post so far, why don't more people just tap into the bottom of the exhaust manifold and read right from there? is it harder to get to? another thing is exhaust wrap. i have some sittin around i was finally gonna install on my Y. should i put that on there, will it throw my readings off a lot should i just have a bung welded onto the y-pipe itself? thanks!!
Old Oct 24, 2002 | 05:08 AM
ejj's Avatar
ejj
I didn't because I figured it would make it tough to return to stock to sell. Finding a new header is tough, new Y-Pipe's are easy.
Old Oct 24, 2002 | 05:23 AM
Stephen Max's Avatar
I'd be very surprised if anyone but the most hardcore car freak discovered the hole in your exhaust manifold (assuming you replaced the sensor with a pipe plug, of course).
Old Oct 24, 2002 | 07:22 AM
ejj's Avatar
ejj
Of course...however with the sensor that I had, there isn't a threaded "bung" installed...just a hole drilled. So plugging it would not be easy.
Old Oct 24, 2002 | 09:32 AM
WizzaMax's Avatar
The Autometer EGT I used I opted to weld on the bung on the front bank part of the y-pipe, that way, I can either insert proper threaded plug if I need to remove the gauge for any reason or I could weld it shut for more permanent change.
I looked at the choice for the metal band to hold it on but thought it best to secure it firmly...
Old Oct 24, 2002 | 09:52 AM
That is what I am going to do...... bung away
Old Oct 24, 2002 | 01:06 PM
Chunger's Avatar
My other car is a Hybrid
If you do it correctly... you don't even have to modify the heatshield.
Old Oct 24, 2002 | 01:57 PM
Do a quick search, but I have read that header wrap is a big no no on Y pipes. You can get 2 egt's and do individual banks if you'd like. Honestly, I don't see that as a big advantage due to the fact the egt is used to monitor mostly and not diagnose. In other words, if you see the egt go too high, you shut down. If you go too high and don't see it, you go boom. You cant repair 1 bank of cylinders only, just all at once. Also, unless you are direct port, you have no way to "tune" in cylinders individually anyway. I think most people mount high up in the front bank due to historically lean #4 cylinder (not 100% on that number).
Old Oct 24, 2002 | 02:24 PM
I can't tell from the picture. is that in the exhaust manifold?
Thanks,
D
Old Oct 24, 2002 | 03:26 PM
Chunger's Avatar
Thanks,
D
Yes, at the collect area.
Top pic from front of car (near battery) looking down.
Bottom pic you can see the radiator on the right.
There is a cut out on the heatshield that will accommodate the probe without cutting... You wills still need a drill/tap...
I have better pics if you plan to do it this way... email me.
Old Oct 30, 2002 | 11:02 AM
If you do it correctly... you don't even have to modify the heatshield. [/B]
How were you able to drill the hole in the manifold? I can't figure out how to get a drill in the confined space between the radiator and manifold. Small air drill?
Old Oct 30, 2002 | 01:12 PM
Chunger's Avatar
90 degree Makita drill... helps to have tools.
I also removed the radiator fans.
Old Oct 30, 2002 | 02:30 PM
Chunger's Avatar
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
