KYB+Sprint give me a Bouncy feel.......
Old Oct 26, 2002 | 04:56 PM
YUTAKARNB's Avatar
KYB+Sprint give me a Bouncy feel...WHY?
Hi! I just installed my KYB AGX and Sprint lower spring, Addco swaybar , and Stillen FSTB and RSTB, Brembo Rotor, AXXIS brake pad. After we finished installation, I tested my car. The handling was good , but it gave me a bouncy feeling , not stable on the bumppy road. I tried to adjust the shock to be the hardest level (front 4 , rear 8), it still didn't give me a smooth ride. What is your setting on KYB AGX + spring. Should I try to set the shock to the lowest level? What should I do ?
PS: I didn't change my rims to be 18'', I used stock rims when I tested my car, it that maybe a reason to me to feel bouncy ?
If I need a comfy and smooth ride, do I have to change to have new set of spring?
Old Oct 26, 2002 | 05:20 PM
meccanoble's Avatar
Sports Button FTW
Re: KYB+Sprint give me a Bouncy feel.......
i got that same set up (spring and kyb and i have kyb at 2 and 4). It is mad bouncy. the car takes every bump and eats it but its like mad bumpy. Not too bad for me to complain but for better handling i guess its worth it. I stick to the ground
Old Oct 27, 2002 | 01:19 AM
YUTAKARNB's Avatar
I tried to decrease the strut setting to #1 for both front and rear. Now it is giving me a smooth ride............... Not bouncy any more...........I LOVE IT Very good handling, no one can't beat Sprint price and performance
Old Oct 27, 2002 | 07:56 AM
Chebosto's Avatar
RIceD OuT moDErAtor
there is BOUNCY, and STIFF
bouncy is like a spring oscillation, as if the car was like a caddy. if THAT is happening, then turn up the rebound settings on your AGX.
if it's too STIFF, as is bone jarring, then turn it down.
Old Oct 27, 2002 | 08:44 AM
Sin's Avatar
Sin
That doesn't make sense. I think you are taking about stiffness and not bounce. Bounce is caused by compression of the spring, and for the tendency for the car to bounce after hitting a bump, which is why we use shock absorbers. They basically work against the spring. When you stiffen up a shock, the spring's actions are impeded, therefore after hitting a bump, it stops bouncing sooner, but makes bump absorption a little stiffer. When you loosen a shock, the spring is allowed to work more freely, therefore, after hitting a bump, it would allow more bouncing.
This is why when you see a car with blown out shocks, it bounces like mad.
Old Oct 27, 2002 | 08:20 PM
StygianMax's Avatar
I think you've got the softest settings on your front/rear agxs.
Pnjboyzz
Nov 16, 2015 12:27 PM
Marc2theMax
Sep 28, 2015 08:13 AM
Sep 27, 2015 08:37 AM
lrb6805
Sep 24, 2015 05:03 PM
