Question for 5speed owners
Old Oct 27, 2002 | 03:58 AM
Sold the Camry's Avatar
I have a question I hope will be an easy one. Just bought my car a couple months ago, and I have noticed that when comming to a stop, I push in the clutch and my RPMs drop all the way down to 750 or sometimes even lower when rolling to a stop, and then its like the vaccuum or something catches it just in time and it jumps back up over 1000 or so. Not very smooth at all, is this normal, have been driving autos for a long time now. Also on start ups the RPMs rev way high for a few seconds and way slower than I'm used to start to go down. Is this the normal fast idle?, or maybe throttle cable adjusted too tight? My warm idle is at 600 is this fine or is there an advantage to raising it to 750 or 1000, sorry so long, but wanted to drive for a while before asking. Thanks
Old Oct 27, 2002 | 04:20 AM
Sprint's Avatar
your idle is suppose to be at 500 / 600 rpms at idle and 1000 with the AC on
Old Oct 27, 2002 | 07:12 AM
kratz74's Avatar
Yes this is normal
This is also normal
This does NOT sound normal. Is it like the car feels about to stall and the rpms jump back up? Wonder if it is an O2 sensor or fuel injector. Have you chekced to see if you haver any computer codes? That'd be the first step to see if you have a problem here.
Old Oct 27, 2002 | 07:15 AM
pjalst
Originally posted by kratz74
Yes this is normal
This is also normal
Clean out the trottle body and if that doesn't work change the plugs. It worked for me.
Old Oct 27, 2002 | 08:29 AM
MaximaRox's Avatar
Re: Question for 5speed owners
the idle is supposed to be at 500-600 and 1000 with AC on. your rpms dropping on pushing the clutch in is normail behavior. when you push in the clutch, it disengages the engine from the drivetrain, thus taking the load of the engine and the engine revs start dropping till the stabilize at the idle speed of around 500. another thing that you will observe is, when you shift the car to 1st from idle, your engine rpms will drop a little below the idle rpm of 500 and then they will start increasing once you apply the throttle. this happens because the engine is running without any load at idle (500 rpm). when you put the car in 1st, the engine is engaged with the drivetrain, thus putting some load on it and the rpms drops slightly. as you start applying the gas, the engine will rev up and you will start to move.
hope that clears all your questions.
Old Oct 27, 2002 | 10:32 AM
Thanks, for the amswers, I understand the pushing in the clutch will make the rpms drop, it just seemed to drop real low when rolling to a stop and then jumping back up to over 1000 rpms before settling back down. I cleaned the throttle body, and have new plugs, also ran the codes and nothing. So for now I'll take it as normal, because it never seems to get low enough to start to stall. I thought maybe a vaccuum issue or throttle cable issue. Thanks for the help!
Old Oct 27, 2002 | 10:38 AM
Nealoc187's Avatar
SLOW
My car exhibits these exact symptoms when I have my governor switched off, meaning I have the switch flipped so my transmission speed sensor wire is not connected to the ECU. I've never figured out the correlation between transmission speed sensor and idle, but there is obviously some connection. When I flip the switch back to the "on" (stock) position, I have no idle problems. I don't think this is the case with your car, as you have an SE and no governor. Unless by chance you have a bad transmission speed sensor or disconnected wire.
Old Oct 27, 2002 | 02:45 PM
JeffesonM's Avatar
living out of a maxima...
maybe it adjusts the idle when it thinks you're stopped
Mar 12, 2020 12:06 AM
Maximan190
Dec 16, 2015 06:01 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Johnny9595
Sep 3, 2015 05:18 AM
Lowered_a33
Sep 1, 2015 07:49 PM
