AGX bumpstop/dustboot - does it or doesn't it fit?
njmaxseltd says the AGX dustboots won't fit correctly whereas others indicate they do fit.
Someone else mentioned that the Nissan replacement dustboots are much better quality than the thin OEM ones and recommended using the Nissan replacements.
Bottom line - which dustboot should I use if I am installing AGX/Maxspeeds on my 96 GLE? For those who have installed AGX struts and dustboots on a 96, did the dustboots fit correctly?
On another note, does anyone know if the Motivational rear upper mount will work correctly with AGX struts or are they designed specifically for Koni rear struts only?
Re: AGX bumpstop/dustboot - does it or doesn't it fit?
The KYB covers are Zip Tied onto the strut/shock and stand up on their own from there. They work, but I don't like the design. They should hang down, not stand up.
my KYB dustboots/bumpstops fit fine. they were a big pain to get over the strut piston though. at first it doesnt seem like they fit, but a little elbow grease slides them over the top of the piston. i also had to push them up on the piston after getting everything in the assembly together (wedging my hand inside of the spring and pushing the boot up to the top of the strut assembly). the zip-tie is kind of odd...but the quality of the boot and not having to trim the bumpstop makes it worthwhile to me.
Thanks guys for the quick responses.
njmaxseltd, since the dustboot fits snugly on the strut piston, is the zip tie really necessary? Would not using the zip tie cause the dustboot to interfere with the movement of the strut piston? Also, is it only the fronts that need this or the rears too?
Finally, is anyone using the motivational rear upper mounts with AGX struts? Do the rear mounts work with any brand of spring and shock?
Thanks again.
Thanks again.
I actaully disagree with Tom on this; the dustboots in the rear fit the same way as the OEM's, but prevent debris from going up into the pitson are by zip-tying at the bottom. The zip tie doesn't support the boot, it's merely closes the end of it.
However, I don't know how the fronts are. I only have the rears.
Originally posted by Requin6
the fronts are the same deal...just slightly different shape. and yes i am with you on the support issue. the boot is held on the strut piston up top...the zip-tie just closes the bottom off.
Front Dustboots:
You can just barely see the black zip tie at the bottom of the dustboot. I think I helped Tom see the light of the KYB dustboots
However, I still believe that he's the suspension master
-hype
-hype
jchronis2552
09-23-2015 04:57 PM
carid
09-09-2015 05:06 AM
boomerbrian
09-02-2015 03:46 PM
