When tune up is done, does timing need to be adjusted?
Old Oct 28, 2002 | 09:30 PM
Mikesburn's Avatar
When I went to the tune up shop, guys told me that tune up is only the spark plug replacement. When I've asked if any timing should be adjusted, they told me that it gets adjusted automaticaly.
Is it really truth?
Thanx
Mike A.
Old Oct 28, 2002 | 09:43 PM
gambit's Avatar
Replacing sparkplugs is only part of a tuneup. You still have to change the air filter, fuel filter, oil and oil filter and examine all belts, lines, exhaust, and fluids. The radiator needs flushing, the transaxle oil could need replacing and the drive belt could also need replacing. After all that, you also need to lube up everything. If you take it to a mechanic, it can cost $300 for a tune up. It's a lot more than just plugs.
-Gambit
Old Oct 28, 2002 | 09:44 PM
Max4U's Avatar
Re: When tune up is done, does timing need to be adjusted?
Is it really truth?
Thanx
Mike A.
You should also replace the gas filter, air filter, and PCV valve.
And yes the ECU automaticaly senses the changes and adjust any timing that is needed.
Clive.
Old Oct 28, 2002 | 10:41 PM
JsL's Avatar
JsL
Timing does not need to be adjusted for a maxima because it has direct ignition. The timing should be checked for cars that have a distributor cap and adjusted accordingly.
Old Oct 29, 2002 | 10:56 AM
Mikesburn's Avatar
Thanx guys! It all helps. Now what is the PCV valve and what part of work does it do for the performance?
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
t6378tp
Aug 24, 2015 07:03 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
