question about whwn changing rotors...
Old Oct 29, 2002 | 09:19 PM
Dayle97SE's Avatar
The front rotors on my max are warped, i'm pretty sure because the steering wheel shakes and the car and brakes pulsate heavily when i'm stopping. I'm going to replace them but i want to know if i need to change the pads too?, my pads are pretty new and have alot of meat left on them, i would hate to have to spend more money and change them too, any info is appreciated. thanks
Old Oct 29, 2002 | 09:26 PM
JDM4LIFE's Avatar
Re: question about whwn changing rotors...
unfortunately, should your rotors be warped, your pads may be unevenly worn. this isn't necessarily true all the time, but it's a big problem when replacing warped rotors. btw, remember, when taking off pads, please (for your car's sake), use the proper lubricants behind the pads, not wheel bearing grease (ugh, midas.....). good luck either way!
Old Oct 30, 2002 | 06:15 AM
sinewave's Avatar
I don't think you'll have a problem. The pads do have some play in the caliper and should float enough to overcome any unevenness. You could resurface the pads by laying a sheet of med-course sandpaper on a flat surface and rub the pads over it in a figure-eight pattern.
Old Oct 30, 2002 | 06:27 AM
craigmax's Avatar
Is there a thread on how to do a complete brake job in our forum? I need some help. Thanks!
Old Oct 30, 2002 | 07:42 AM
jbreit's Avatar
I've tried to skimp on this in the past a couple time...once i even tried sanding the pads down some on a flat surface and still messed up the new rotors.....
good luck....
markevans999
Oct 25, 2015 08:27 AM
Courtneysnow
Sep 4, 2015 05:10 PM
boomerbrian
Sep 4, 2015 08:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
