The life of Double Sided Tape
Old Nov 1, 2002 | 06:22 AM
funnylittlman's Avatar
All,
I have done a search for the Stillen Body kit, and the consensus is to use Double Sided tape a lot for the front of the front lip, the side skirts, and part of the rear sections.
My question is this: has anyone had problems with it falling off (the side skirts or front) where the Tape was, due to hot weather, water, snow, ice, etc? AND how long has it lasted for you....... has anyone had to retape also?
THANK YOU FOR ALL OF YOUR ADVICE, (and flames as well! )
Old Nov 1, 2002 | 07:00 AM
Kashoggio's Avatar
3m makes a double sided tape that will hold up up to 5 pounds or something like that... its the strongest thing I have found and I have used it for everything
Old Nov 1, 2002 | 07:33 AM
clee130's Avatar
Just make sure it's a grey or white color and has a foamy texture to it. It's not the flat masking type tape. It is a "thick" type of tape.
Old Nov 1, 2002 | 07:50 AM
clee130
No problems, right? Would heat "loosen" the adhesive?
Old Nov 1, 2002 | 08:02 AM
njmaxseltd's Avatar
Put a couple of screws in that kit to hold it on.
Trust me - you really don't want to find it dragging behind you one day, and you will if you only use tape.
Old Nov 1, 2002 | 08:08 AM
erty67's Avatar
Decal Specialist
WARNING....I used the double-sided tape that came with the kit, and it all came undone. I strongly suggest using grey 3M tape like Kashoggio was talking about. Also, I would suggest putting a couple of screws in the top of the side skirts(in the door jam area) and a couple screws in the back pieces thru the back bumper. I can send you a couple pics of where I put mine in the rear skirts, if you'd like.
Old Nov 1, 2002 | 08:10 AM
clee130's Avatar
Yes, heat will make the tape more susceptible to loosening. Try adding in some screws like njmaxseltd said.
Old Nov 1, 2002 | 08:11 AM
Yea! Would you send them to me,? 'Preciate it.
Old Nov 1, 2002 | 08:18 AM
erty67's Avatar
Decal Specialist
Check out my homepage(page 6). I added two pics. They are not great, but they'll give you an idea of what to do. I would take more, but I do not have a digital camera. Hope it helps!
Old Nov 1, 2002 | 08:24 AM
1MAX2NV's Avatar
You can get quality 3M tapes from Autobody supply shops. They aren't cheap. I think I got a huge roll for $40 that's enough to installed 6 full body kits with.
Old Nov 1, 2002 | 08:49 AM
Thnx both 1max2nv and erty67
Old Nov 1, 2002 | 09:13 AM
NYCe MaXiMa's Avatar
did you use stock holes for these screws?
i will be installing my kit as soon as i get it painted..
i was wondering about the screws thing..
i don't want to drill into the car..
Old Nov 1, 2002 | 12:58 PM
erty67's Avatar
Decal Specialist
I actually used galvanized drywall screws that I had from work. Where I screwed through the inner part of the molding and rear bumper are both plastic. Drilling was not needed. The tricky part is getting a screwdriver up in there.
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
BrandonCause
Sep 14, 2015 10:41 PM
