What can be the cause of a stiff clutch?
Old Nov 1, 2002 | 09:06 AM
NYCe MaXiMa's Avatar
I've tried different 4th gens and the clutch is not the same as mine..
When i depress my clutch, about 1/2 way through it starts to make a nasty sqeaking/screetching noise and it does not go down smooth..
Someone suggested the Slave cylinder? (i think)
any ideas?
thanks
Old Nov 1, 2002 | 10:17 AM
njmaxseltd's Avatar
Where is the noise from? If inside the car then it's your pedal binding up. If it's outside it could be the slave cylinder, clutch pressure plate or release bearing or throw out bearing.
Old Nov 1, 2002 | 10:20 AM
190hpKiLLA's Avatar
Granny Driven
The sound is coming from under the hood where the slave cylinder is.
Old Nov 1, 2002 | 10:49 AM
blizz20oma's Avatar
I'm so hood
Yea, I developed the squeak/screech about a month ago. From the searches I did it was just an area that had to be lubed, but was rough to get to, as in...drop-the-tranny rough I think? I'm 98% sure my throwout bearing is shot so I'm just planning on getting a new clutch next year anyway, and making sure the proper areas are lubed while it's open down there. I think I searched for "clutch" AND "squeak" and found the info, there were a couple threads that DBM posted in. Those are always good for reference.
It kinda sucks...between the squeak (and added resistance that came with it) and the rumbling/vibrating in my pedal coming from what I assume to be the t.o. bearing, it's not easy to drive the max smoothly all the time.
Old Nov 1, 2002 | 10:55 AM
SuDZ's Avatar
Sounds likea good excuse to get an ACT clutch and fix it while your at it.
SuDZ
Old Nov 1, 2002 | 01:35 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: What can be the cause of a stiff clutch?
any ideas?
thanks
I remember replying in this thread:
http://forums.maxima.org/showthread....hreadid=125079
HTH
Old Nov 2, 2002 | 10:58 AM
that sounds exactly like what i am experiencing!
and i agree with you
it plays on your foot.. sometimes i have to stomp the clutch, sometimes it is harder to release it smooth.. definately messes with my driving, not to mention annoying the hell out of me..
Old Nov 2, 2002 | 11:33 AM
Re: Re: What can be the cause of a stiff clutch?
HTH
thanks
i'm going to try greasing it..
btw,
anyone know how hard is it to replace your throw out bearing and how much the part costs?
Old Nov 2, 2002 | 12:24 PM
VeeQueue's Avatar
Re: Re: Re: What can be the cause of a stiff clutch?
thanks
btw,
They are $25 or so seperately. You have to pull out the tranny to replace the throw out bearing. It becomes a clutch job anyway since the tranny is already off the car. They are usually included with a clutch kit.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
