Suspension - pics
Suspension - pics
I finished replacing all four struts/shocks yesterday. It was a bit more work than I expected but I think a lot of that was inexperience. The car rides beautifully now -- no surprise since I discovered that one of the struts was completely blown when I took it out.
I also replaced the front bearings and insulators, front and rear rubber seals (isolation sleeves) and all four dust covers.
Thanks to everyone for your patience and advice. I couldn't have done this without you guys.
The new right front strut:
Originally posted by PRPmax
What kind of springs and struts are those? .. I'm running the Eibach and Tokico combo. Not to happy with the wheel gap the Eibachs leave.
But performance wise I can't complain. Enjoy your new found, more performing maxima.
Yeah, they're a bit on the vintage side.
Here's a closeup of the blown strut. Might not be too obvious but there is fluid on the cylinder and the rod moves in and out without resistance. Basically, I'd been riding on the spring on that corner.
Originally posted by njmaxseltd
Excellent work! How do those GR2's ride? Should be much tighter then before, that for sure.
Doesn't it feel good to do it yourself?
I think the GR2's are a little bit firmer than the stock struts. But the ride is firm, solid, and smooth. It's definitely tighter than it was. I drove up to Dallas Thursday to pick up the parts at Courtesy Nissan and there was an obvous tendency for the car to float on bumps on I-45 at 75mph. Now I feel the bumps but the car holds the line like it was new.
Originally posted by chigga
how hard was install? i might do mine by myself if its not too hard. do u need xperience to do it or pretty much just read the instructions????
Basically the best advice I got was to use a 1/2" ratchet, a breaker bar, and a lot of WD-40 for the fronts. The bolts on the knuckle are very tight and the breaker bar is a must. If you have air tools, all the better. You will need a spring compressor. I borrowed one from Auto Zone -- $40 deposit refunded when you bring it back.
For the rears, the lock nut is a PITA. I used a nut breaker since the new shocks come with a new nut. Then the only tricky bit is to line up the two mounting studs with the sleeve on the bottom of the strut when you install the new one.
It does help to have a second pair of hands too.
Re: cool
Originally posted by +COLLANA+
my shocks are about worn out too and I was thinking about the struts...
I'm going with AGX. I heard it is the best. And how much did you lower your car?
Originally posted by BlackSE5spd
So how long does it take to do the job?
04-16-2020 05:15 AM
bigfrank
10-01-2015 12:51 PM
