Flashing Air Bag Light
Old Nov 4, 2002 | 10:46 AM
hornsounder's Avatar
Help! My battery died, and since then the Air Bag light started flashing. I figured that it would reset after I changed the battery, but it didn't. Does anybody know if I can reset it somehow?
Old Nov 6, 2002 | 01:21 AM
sryth's Avatar
Re: Flashing Air Bag Light
Open your driver side door, turn the key to ON (don't start the car), depress the door switch (the rubber button in the door frame that makes the dome light go off) 5 times.
This will reset the airbag system. If there is a legitimate problem, the light will return.
Old Nov 6, 2002 | 01:34 AM
pezking4's Avatar
Re: Re: Flashing Air Bag Light
Quick question: if your car does not have an airbag and it was originally equiped with one will the car pass inspection?
Old Nov 7, 2002 | 06:22 PM
sryth's Avatar
Re: Re: Re: Flashing Air Bag Light
It doesn't say anything at all about airbags here: http://www.dmv.dot.state.nc.us/drive...nspection.html
I would doubt they could fail you for non functioning airbags, but anything is possible.
Old Nov 7, 2002 | 06:58 PM
Nismo82's Avatar
Man - where the hell did you hear of that trick? What happens if you pop the gas tank 7 times, flip on the dome light twice, open the center console, than turn on the windsheild wipers?
Old Nov 7, 2002 | 07:00 PM
JustTry's Avatar
You dont know?!?! Thats the trick that gives you +50HP- duh!
Old Nov 7, 2002 | 08:52 PM
Maximaguy96''s Avatar
air bag inspection...
In the state of NC you do not need air bags to pass inspection.... There is no where on the inspection sheets that requires an airbag check... hope this helps.. Jason
Old Nov 7, 2002 | 09:08 PM
To figure out whats wrong you need to count the flashes given by the light......
2 flashes= air bag module circuit is out of order..
7 flashes= Diagnosis sensor is out of order...
8 flashes= front passenger air bag module circuit is out of order.
I have the repair orders of what to do when you find out what the problem is... AIR BAG OPPERATIONS SHOULD ONLY BE PREFORMED BY A QUALIFIED PERSON.... DO NOT ATTEMPT TO HANDEL AIR BAG PROBLEMS YOURSELF OR INJURY OR DEATH MAY RESULT !!!!!!!!!!!!!!!!! The only way to reset the system is to do it by computer.. sorry... Hope this helps. if you have any questions email me.... Maxima_gle@hotmail.com
Old Nov 9, 2002 | 04:10 AM
sryth's Avatar
Here, of course
Old Nov 9, 2002 | 05:54 AM
PhatBastard's Avatar
What if the air bag light is just on (not flashing)?
Old Nov 9, 2002 | 10:13 AM
sil SE's Avatar
no this works. opening the door, pushing dome light switch 5-7 times puts you into air bag diagnostic mode for the light
Old Nov 9, 2002 | 05:15 PM
Sorry... I dont know on that one......???????
Old Nov 9, 2002 | 07:11 PM
Nismo82's Avatar
Re: Re: Re: Re: Flashing Air Bag Light
what other tricks are there? LINK?
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
