Rear Brakes squeaking (suggestions?)
I just replaced my original rear brake pads in a '97 Maxima SE with the Raybestos Quiet Stop pads. The pads fit perfectly and the Disc Brake Caliper loaner tool from AutoZone made the job very quick and easy.
The brakes work great when the car is rolling forward, but when I put it in reverse and back up, the brakes squeak. Has anyone else had a problem with this?
I re-used the old Nissan shims from the original brake pads. The Raybestos QS shims were totally worthless. I also used the grey compound on both sides of the shims and I also put a very thin spread of the grey anti-squeak compound on the flat metal spring runners on the top and bottom side of the caliper.
Any comments would be appreciated.
Thanks.
Thanks.
Check your calipers, they might not be working correctly.
I had a "hum"ing noise when I first got my max. I took it to a shop, and they said that the rear caliper froze. I had to get a new replacement. Since then, no prob bob!
How long have they been in there now? Might just wait about 300 miles and see if it stops.
What condition were the old Nissan shims in?
Did you remove and regrease the caliper pins?
The caliper pins need high temp grease on them. Those are the pins that the cailper bolts onto. You just remove the boot and slide the pin out. Clean it off, apply a light coating of high temp grease and put the pin back in and put the boot back in place. If those pins don't move in and out freely, the caliper will not function correctly. I think most guys on here that do their own brakes over look that process. IMHO I think it's a must at every brake job!
Re: Rear Brakes squeaking (suggestions?)
Thanks.
Thanks.
I'm confused. Let's say the problem is with sticky caliper pins, would that result in noise being heard with the Max moving in reverse ONLY but not while going forward?
Gee, we have a reverse-warning system just like trucks have!
j/k
j/k
Originally posted by Rogo98SE
Where did you guys buy the Raybestos.
It's time for rear break job and I think that OE are not worth the money (For the rear).
j/k
j/k
Huttig2009
Sep 25, 2015 03:31 PM
MikesChevelle
Aug 7, 2015 05:57 PM
