post if boosting 10psi+ (3.125 pulley, or smaller)
Old Nov 5, 2002 | 10:20 AM
96bstdSE's Avatar
just wandering what the boost community holds number wise...
number of people with blowers/number of people boosting higher amounts
Old Nov 5, 2002 | 10:21 AM
Jeff92se's Avatar
I'm needing a caw
I'm running 12 psi of search
Old Nov 5, 2002 | 10:24 AM
1MAX2NV's Avatar
My gauge reads 1000 psi a few times. I don't even need a pulley
Old Nov 5, 2002 | 10:33 AM
Stephen Max's Avatar
Re: post if boosting 10psi+ (3.125 pulley, or smaller)
Are you getting 11 psi with a 3.125 pulley on a V2 or a V1 blower?
Old Nov 5, 2002 | 10:34 AM
96bstdSE's Avatar
i've thought about that a few times, lets just shorten the belt, and ride on the pulley bolt
Old Nov 5, 2002 | 10:35 AM
Cumalot's Avatar
I'm running the 3.125 pulley on a V1. Only getting 9psi though.
Old Nov 5, 2002 | 10:41 AM
96bstdSE's Avatar
running 3.125 on the V2 and now peaking at 10.5 psi
Old Nov 5, 2002 | 10:46 AM
Sprint's Avatar
i remember when your car did 14 PSI.. too bad you never saw it
Old Nov 5, 2002 | 10:47 AM
iansw's Avatar
Souns about right.
I'm running a 3.25" on a V1, and hitting 7.5-8.5PSI (9 a couple of times)
The V1 seems to boost about 1-1.5PSI less than the V2.
Those of you with 3.125" Pulleys, what extra stuff are you running fuel wise? Walbro? Injectors? etc....
IanS
Old Nov 5, 2002 | 10:53 AM
96bstdSE's Avatar
were u at the shop when the car recieved the 3.33 pulley,NO...........were u at the shop when we put the 3.125 pulley on.....NO,
unless the car hit 14psi on the 3.60 pulley then u dream to much
Old Nov 5, 2002 | 10:59 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I remember hitting 11... and I will be hitting 11.
Old Nov 5, 2002 | 12:32 PM
Sprint's Avatar
no but i was there when it had the 2.XX pulley
Old Nov 5, 2002 | 12:51 PM
dashingMax's Avatar
Following people are running 3.125 or smaller on 4th gen
MardiGrasMax
Cumalot
i30Krab
Jay25 ?? could be 3.25 not sure.
BrianV ?? could be 3.25 not sure.
Chebosto ?? could be 3.25 not sure.
You will find more peeps with smaller pulleys on the 5th gen.
EDIT:
Delio - 3.0"
SighMax - 3.125"
SteveChicagoSC - 3.0"
Furbis112 - 2.xx"
Old Nov 5, 2002 | 01:33 PM
gtr_rider's Avatar
192.168.1.1
Old Nov 5, 2002 | 01:41 PM
delio's Avatar
MardiGrasMax
Cumalot
i30Krab
Bobby you forgot me... 3" soon to be 2.62
Old Nov 5, 2002 | 01:48 PM
dashingMax's Avatar
Whoa! what other upgrades do you have/plan on with the 2.62?
oh!...I edited the above post.
Old Nov 5, 2002 | 03:24 PM
Sprint's Avatar
stock fuel
Old Nov 5, 2002 | 06:21 PM
OgreDave's Avatar
Stock fuel is one of my biggest concerns w/the 3.25
Old Nov 5, 2002 | 06:22 PM
iansw's Avatar
What do you mean?
Sotck as in Vortech FMU is not existant, or as in stock FMu disc nad/or no Aux Fuel pump?
Or do you mean 91+ octane?
IanS
Old Nov 5, 2002 | 08:25 PM
OgreDave's Avatar
Originally posted by iansw
What do you mean?
IanS
PLUS??? They downgraded us in CA to 91 ... thats all we can get short of 'race gas' which is a pain .. but i have a V1, so it SHOULD be ok .. decisions decisions ..
Old Nov 6, 2002 | 06:25 AM
MardiGrasMax's Avatar
Running a 2.62" and last I really looked it was ~13psi peak. Now that I'm in DC and its winter with denser air I wouldnt be suprised if I get 14psi.
Other helpfull items...
J&S Safeguard
370cc injectors
4:1 FMU (3:1 will work too IMHO, but if you use an AFC to pull MAF voltage you will get more ignition advance because the motor thinks its flowing less air and it gives more timing )
Fields AFC
As soon as I get the 3" exhaust system I will dyno her again and see how shes doing
Old Nov 6, 2002 | 06:45 AM
Jason R's Avatar
aka UNCDooD
i want some BOOST damnit! lol
Old Nov 6, 2002 | 07:39 AM
Y2KevSE's Avatar
MardiGrasMax
Cumalot
i30Krab
EDIT:
Delio - 3.0"
SighMax - 3.125"
Furbis112 - 2.xx"
Jane97SE - 2.87"
Old Nov 6, 2002 | 07:47 AM
Jer's Avatar
Jer
I love cooler air; I wonder if it has anything to do with my boost peaking at 8 on my 3.33!!! I noticed it the moment I made my first run last week... on a V2 though..
J&S Safeguard
370cc injectors
Fields AFC
Old Nov 6, 2002 | 11:50 AM
dashingMax's Avatar
8psi boost using 3.33 on V2 is correct.
Occasionally, I've hit full 9 psi with my 3.33" on a cold morning in second gear!
Old Nov 6, 2002 | 03:52 PM
brodaiga's Avatar
my SC
I have a 2.87 pulley with 370cc and JWT ECU. Testing it out with Jay25 it pushed 11psi, prob loose a couple psi with the intercooler, but hey, that's more important.
Old Nov 6, 2002 | 04:11 PM
dashingMax's Avatar
Re: my SC
You're lucky since you have a 1995 model.
Us, 1998+ do NOT have any ECU options that would work with 370cc
Old Nov 6, 2002 | 04:57 PM
SuDZ's Avatar
J&S Safeguard
370cc injectors
Fields AFC
Where do you figure your at HP/TQ wise? Just as a guess.
SuDZ
Old Nov 7, 2002 | 06:20 AM
JAY25's Avatar
SuDZ
3.25 Pulley boosting 10PSI. I have the Apexi SAFC but have not tuned it yet. I am waiting on the ME VI. I will tune it then.
Old Nov 7, 2002 | 06:30 AM
Re: my SC
So have you and Jay raced? Who won?
Old Nov 7, 2002 | 06:41 AM
SuDZ
Last dyno was ~320whp/260wtq SAE with ~9.5psi from a 3.125". Since then I have added more boost (2.62"), modified the cross over tube to 3" and changed the elbow fitting off the blower for better flow, ported my MAF, added the 70mm throttle body and opened the TB port on the intake manifold and installed the J&S safeguard. I think ~350whp/290wtq SAE is a safe bet for now. After I install a full 3" exhaust it should be neer ~370whp/320wtq SAE. My exhaust now is a 2.5" Stillen Y, 2.5 Test Pipe, 2.5 B pipe, 2.25" inlet 2000 variable muffler. The 2k muffler is choking some serious power, but its quiet. I plan to also try to tune in a G Force ECU that is modified for a normally asperated car, the extra timing in the mid range will help the low end torque ALLOT, and with the J&S it wont be a problem.
Old Nov 7, 2002 | 07:58 AM
dashingMax's Avatar
Re: Re: my SC
YEAH!!!
Hey Brodaiga!
We would ALL like to see the performance of the JWT ECU with 370cc injectors.
Why don't you and JAY25 have a race. If someone can video tape it, even better, but we trust you and Jaime.
GO...GO...GO...GO...GO...GO...
Old Nov 7, 2002 | 08:13 AM
Sprint's Avatar
I don't think he will race Jay because he know he won't win..
come on man.. look at Jay's Motor.. thats got to be one of the strongest motor's on the org.. he is boosting way more than lots of people with a bigger pulley..
i don't care if you have JWT and 370 injectors.. Jay will win..
Old Nov 7, 2002 | 08:51 AM
dashingMax's Avatar
Chicken!!!
puck...puck...puck...puck...puck...puck...puck...p uck...puck...puck...puck...puck...puck...puck...pu ck...puck...puck...puck...puck...
Old Nov 7, 2002 | 09:44 AM
turbo97SE's Avatar
Matt, you should try the quicktime electric cutout, or some other cutout. I plan to install mine soon so I can put a quieter muffler on my car without affecting flow when I want to goooooooooooo!
Old Nov 7, 2002 | 10:35 AM
Chicken!!!
Psycho chicken, run run run awaaaaay, puckpuck a puckpuck puck a puckpuck
Sorry!
Old Nov 7, 2002 | 10:52 AM
I was thinking about that
Old Nov 7, 2002 | 05:00 PM
turbo97SE's Avatar
Dude I emailed you a couple of times but no reply. R U avoiding me?
Old Nov 7, 2002 | 07:35 PM
brodaiga's Avatar
just came home, who u callin chicken mother**#(#, lol. I'm down for a race, but only on the track. Should be pretty interesting. Will be even more interesting when we get our vi's and get our cars tuned. As always, sprintmax is out to diss others, i choose to ignore. Jay and I were looking at my setup, and apparently, I don't even have an FMU installed, he said he's never really seen a setup like mine, so it should be pretty interesting. I just have to get better with launches... (never been to track before)
Old Nov 7, 2002 | 07:39 PM
JAY25's Avatar
They are just playing around. Listen the reason why you dont have a FMU is because I believe that the ECU you have controls the flow of fuel thru the 370CC injectors. Racing at the track we will never line up trust me on that one. Your better off racing from a rolling start you saw how your car broke loose when I took you on that test drive.
