Brake question. Please help.
Old Nov 5, 2002 | 08:33 PM
RAZER's Avatar
I did my back brake yesterday and i let some of the fluid out while putting the caliper back on. After that i bleeded the breaks and put more brake fluid in. But today when i went to work i noticed i had to push the brake pedal halfway in for it to start braking. Before as soon as i touched the brake pedal it would start stopping. Could it be because i didnt put those thin backing plates back in? Or did i still leave air in the lines. please help.
Old Nov 6, 2002 | 07:41 PM
finkasaur's Avatar
To me it sounds like you still have air in the lines. I had done the similar goof up once and it took a while to get the air out of the line. Are you taking about the black plate that goes behind the pad? If so, that wouldn't make a dramatic difference in the amount of distance the pedal goes down.
Also, make sure you don't have a "leak" in the line anywhere. Make certain it is airtight and there is pressure.
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
