Need imediate help on PR cold air intake!!
Old Nov 7, 2002 | 09:55 PM
maxperformance's Avatar
how did you get the cuplet over the mass air flow sensor. its such a tight fit?
Old Nov 7, 2002 | 10:03 PM
meccanoble's Avatar
Sports Button FTW
Re: Need imediate help on PR cold air intake!!
cuplet?
Old Nov 7, 2002 | 10:15 PM
Re: Re: Need imediate help on PR cold air intake!!
the black seal
Old Nov 7, 2002 | 11:01 PM
NyC97Max's Avatar
i believe its the "rubber o-seal ring" youre talking bout
cuplet no1 will understand
my solution, i just didnt have one...hahahah
i think when i took apart my stuff last time when cleaning my throttle body, i just did not realize i 4got to put that ring back in...i dunno how much of a difference it makes, i guess its just a tighter seal
jus play around with the tubing and twist the MAF towards the rear of the car more and you'll get a better fit, i know its tight but if u do it one pipe at a time, u wont have a prob, its ok to use sum pressure
Old Nov 7, 2002 | 11:32 PM
Nismo's Avatar
I think your talking about the hose connections, if so then what you can do is run hot water over the rubber "cuplet" so that it will expand and then try to slide it over the MAF.
Old Nov 8, 2002 | 12:23 AM
kj043's Avatar
i had similar problem with my midpipe hose.. jus be patient with it and try to stretch it out. eventually it will slip over the maf. make sure you don't overtighten the clamps, it could crack the plastic.
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
hayne
Oct 5, 2015 11:53 AM
Sep 27, 2015 08:37 AM
