Low compression?
Old Nov 10, 2002 | 03:54 PM
turbo97SE's Avatar
Low compression?
hi
I did a compression test on my car today. I get 160 to 165 psi which still appears to be within spec but a little on the low side. I have read of other people getting over 200 psi! Is mine low? When I add oil to the cylinder, the compression goes up to 190. Worn rings I think!
Old Nov 10, 2002 | 04:13 PM
Ramius83
Re: Low compression?
Originally posted by turbo97SE
hi
Boosting 11.5 psi too much.............j/k
Old Nov 10, 2002 | 05:41 PM
iwannabmw's Avatar
Did you do the test with the engine warm. This can drastically alter the readings from a cold engine and is far more accurate. If you did do it warm, I think you're right about the rings. If the compression rises during a wet test, either the rings or cylinder wall itself is worn.
Old Nov 10, 2002 | 06:57 PM
turbo97SE's Avatar
Actually, I did it when it was cold. I don't like messing with it when it's hot! Yeah, I read the manual about doing it when warm but didn't think it would make a huge difference. I'll try it again when it is warm.
Thanks!
Old Nov 10, 2002 | 07:02 PM
mtrai760's Avatar
'Trynna' is not a word
Did you do a compression test before you were boosted...?
Old Nov 10, 2002 | 09:52 PM
turbo97SE's Avatar
I don't think I mentioned anything about turbo ... just asked if my compression was considered low
Old Nov 11, 2002 | 06:07 AM
ejj's Avatar
ejj
There's a chance that your guage reads low too. I've seen different guages read different things.
The important things (in my mind) are numbers in all six cylinders that are very close, and consistancy over a long range.
IE, if you got 160 before a mod and 160 after, then you have nothing to worry about. However, if by installing something (boost, nitrous, whatever) you go from 180 to 160, you've got problems.
Old Nov 11, 2002 | 06:08 AM
iwannabmw's Avatar
I thought the same thing when I did a compression check on the old BMW I just bought. Cold, the readings were 150,135,145,125,120,120. Considering they are supposed to be between 142-154, these numbers scared me a little. I decided to do the check again after the car was warmed up. The numbers were now, 150,150,145,150,135,150. I'm much happier My guess is that you might see similar results.
Old Nov 17, 2002 | 07:02 PM
iwannabmw's Avatar
HAve you a chance to do a retest yet?
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
