Starting problems with my Maxima...anyone experience this before?
Old Nov 11, 2002 | 11:54 AM
ChoMax's Avatar
Okay, so as I started my engine, it starts right up then the idle goes up and down a little like my car is going to die. Sometimes, when I start the car, it doesn't start at the first time. The second time then it starts. It being doing this to me since last week. My car runs strong, fast, and great after it starts. Nothing wrong ther, but I can't seem to find what the starting problem is...any help would be great. The things I have already done...Check ecu errors(nothing detected), new starter, new fuel filter, and new knock sensor. I have also add new performance parts to my car like exhaust, intake w/ filter, pulley, y pipe, test pipe, and so on. Any help would be great. Thanks.
Old Nov 11, 2002 | 12:34 PM
Mishmosh's Avatar
Re: Starting problems with my Maxima...anyone experience this before?
try cleaning your throttle body. Also check to see where your idle is set out (ie. run car with TPS disconnected).
Old Nov 11, 2002 | 12:44 PM
ChoMax's Avatar
Actually, I did that about 6 month ago...but I'll try cleaning it again. By the way what did you mean by TPS, is it okay to run it disconnected? Thanks.
Old Nov 11, 2002 | 01:47 PM
njmaxseltd's Avatar
TPS= Throttle Position Sensor. No you cann't run with it disconnected. Check the FAQ thread on top, there is also a process for cleaning your IACV valve. (intake Air Control Valve) That valve controls your idle speed. If it's dirty or lazy it may not react fast enough to keep your idle stable upon startup.
Lakersallday24
Jun 16, 2019 01:35 AM
Cotozic
Jun 28, 2017 08:01 PM
Tha'-Max
Aug 30, 2015 01:14 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
Gsantos79
Aug 8, 2015 07:41 AM
