Winterizing my Max and squeeling belts...
Old Nov 11, 2002 | 09:07 PM
kwamdoo74's Avatar
Carpe Diem....
What is done to a car when it is "winterized"? Can I do it myself? And I have noticed a lot of squeeling by my belts. It has been raining around hear, but i don't think it is because of the belts being wet. Is there anyway for me to stop the anoying squeel, or do i need to change my belts. I just noticed the squeeling today. I'll see if it goes away tommorrow after a little bit of driving. Thanks for your input and and your advice on both of these issues.
Old Nov 11, 2002 | 10:39 PM
dgpfx's Avatar
actually, my belts had the same problem. SO i checked around and people said like i would have to replace my pulley, and buy a whole new belt, and it would cost a lot. I was about to spend 50 dollars for an inspection, but my brother told me he was gonna fix it. He went to pepe boyz and bought a BLET DRESS SPRAY. It stops belt squeeling. Actually, it worked. Everytime i start my car its gone and i got no prob. Didnt spend 500 bucks and my stepdad told me that i was a dumbA$$ because i didnt get it fixed. I dont even know the problem but it seems to be fixed. "BELT DRESS" "pepboys"
Old Nov 11, 2002 | 10:41 PM
dgpfx's Avatar
i also replaced my belts earlier because of wear and tear. Go check under your hood to see if you belts are shredded. If not, "BELT DRESS"
Old Nov 12, 2002 | 04:48 AM
kwamdoo74's Avatar
Carpe Diem....
How can i tell whether or not they are "shredded"? Will they literally be shredding to pieces or will they have small cracks on them? Thanks
Old Nov 12, 2002 | 04:57 AM
95Max's Avatar
Belt dress is only a temp fix. I had the same squeeling with 1.5 year old gates belts. I replaced them with Bando and not a sound. See www.bandousa.com for sizes
Old Nov 13, 2002 | 09:27 PM
dgpfx's Avatar
if its cracked then it needs replacement. If its torn on the sides, its needs replacement. Expensive, i got mine replaced 1 month ago but they started squeeking.
But if its fine, use belt dress.
Old Nov 14, 2002 | 04:35 AM
95Max's Avatar
Don't use cheap belts and tighten correctly and you will not need belt dress
Old Nov 14, 2002 | 06:46 AM
funnylittlman's Avatar
Mine were squeakin during these past couple mornings (cold and rainy). It's the sudden changes in weather. I talked to the Nissan guys about it. They said don't worry, b/c they self adjust. Mine only squeaked until I started driving. After about a mile, smooth as a baby's ***. Mine wasn't loud.. I could only hear it a little outside the car.
I would see if your belts are going bad.
Old Nov 14, 2002 | 07:37 AM
kwamdoo74's Avatar
Carpe Diem....
We had a lot of rain a couple of days ago and the temperature dropped a lottle in the DC area, but they quieted down. No more squeel, but what about this winterizing thing. Is it just flushing your anti-freeze or What???
Old Nov 14, 2002 | 07:51 AM
Check your PM bud.
Old Nov 14, 2002 | 07:53 AM
BRIGBOY's Avatar
Silicon Spray, just to lube the pulleys a little, as long as the belts aren't over due to be changed.
Old Nov 14, 2002 | 08:21 AM
95Max's Avatar
Ah...the belts are manually adj.
Old Nov 14, 2002 | 09:05 AM
Sorry about that Moderators!
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
