what do you use to lube the antenna mast?
Old Nov 13, 2002 | 08:10 AM
amb4081's Avatar
Does the electric antenna mast need to have some type of grease or lube to keep smooth operation of the mast? If so, how often and what do you use? Thanks.
Aaron
Old Nov 13, 2002 | 08:19 AM
njmaxseltd's Avatar
WD-40
Old Nov 13, 2002 | 08:23 AM
KMax2988's Avatar
Originally posted by njmaxseltd
WD-40
Either that or white lithium grease.
Old Nov 13, 2002 | 08:37 AM
munji's Avatar
Some people were telling me that WD40 was not good for the antenna, so I used lithium.
Old Nov 13, 2002 | 08:38 AM
Bernie Lomax's Avatar
I put WD40 on it, but it always needs more. Id say every 4 or 5 months the thing doesn't retract.
Old Nov 13, 2002 | 10:38 AM
Ramius83
What you should be using is petroleum jelly. Just put a small amount of jelly at the base of each "level" of the mast when it is up. Then turn the car off and on a few times to work the jelly in. And you can just wipe away the access. Also, petroleum jelly doesn't have an odor, which I have found comes into the cabin when using WD-40.
Old Nov 13, 2002 | 11:13 AM
timmax's Avatar
Dry graphite?
I heard dry graphite was the way to go, and I plan to clean my white lithium off with WD-40 (WD-40 is really a solvent, like gasoline, rather than a lubricant, like oil) and give it a try. Don't know about petrolum jelly, but grease might get too stiff in the winter and tend to overwork the motor. And graphite won't attract dirt the way jelly or grease does.
Old Nov 13, 2002 | 11:48 AM
StygianMax's Avatar
My stinkin' antenna mast doesn't extend all the way & I had been using WD-40. Anyone with ideas on how to get it fully extended. I'll have to look for the dry graphite! Thx for the idea.
Old Nov 13, 2002 | 02:39 PM
ThurzNite's Avatar
I couldn't find dry graphite, so i use dry silicon in a spray can. Works well for me. Also works well to quiet squeeky brushes/tracks for the door windows. It doesn't smear on the window.
Jae
Old Nov 13, 2002 | 02:51 PM
2DMax's Avatar
Clean it, then I use WD-40 on a rag....not a problem in 4.5 years
Old Nov 13, 2002 | 11:53 PM
ThurzNite's Avatar
how often do you'all clean the antenna? my bro says every time he fills gas. I do it when it looks dirty.
Jae
Old Nov 14, 2002 | 04:45 AM
95Max's Avatar
My antenna was sticking about 2 years ago. I lightly greased it with water proof trailer grease and no prob since.
Old Nov 14, 2002 | 04:59 AM
Rogo02SE's Avatar
I used spray silicone.
Workes great!
Old Nov 14, 2002 | 05:15 AM
Rickalodeon's Avatar
Jae
Dry Silicone? Sounds like just the thing for windows & antennas...Is this something that one could find in a Pep Boys, AutoZone, etc.?
Old Nov 14, 2002 | 05:31 AM
funnylittlman's Avatar
Silicone spray... that's what the guys at my nissan dealer say.
Albertt's Avatar
amb4081 >>
You'll want to clean it with WD-40, but then lube it with a thick grease. Dry greases work as well. What you want is a lubricant that does not evaporate, run or allow debris to mix with it.
Old Nov 14, 2002 | 06:06 AM
ThurzNite's Avatar
Re: amb4081 >>
I'm affraid of using anything "wet" cuz junk will catch on it. So I thought of using dry stuff.
Yeah, the dry silicon can be found in an autopart store or hardware store. We got the tip from someone in the 5th gen forum who suggested it after his windows squeeked like crazy. My windows also squeek after I tinted them, but now, no more squeek and no streaking too.
Jae
Old Nov 14, 2002 | 07:58 PM
Dry Silicone?
Jae
So far, at AutoZone, I've found STP Silicone spray that claims "dry quickly" and some graphite powder. But no Dry Silicone. Can you provide the brand name of a product?...Or is it one of the products that I found?
Thanks.
Old Nov 14, 2002 | 08:40 PM
multiplexor's Avatar
i didn't have any lube... so i err.... uhm... well i used Amsoil synthetic oil... hahaha
it actually worked pretty well
it practically stopped working for a while. I cleaned it with a dry cloth and then applied new oil on my fingers and rubbed it up and down the antenna... (don't take that the wrong way!!!)
it's been 6 months and it still works great hehe
Old Nov 16, 2002 | 05:47 PM
zagato27's Avatar
Antenna lube
WD40 sprayed on a paper towel and then applied to the antenna. Cleans off the guck and lubricates. Silicon sounds good too.
Cheers
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
pjgreek
Sep 9, 2015 09:30 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
