Drag Suspension
Old Nov 14, 2002 | 09:39 AM
speedemn's Avatar
Drag Suspension
I was hoping to get some advice on what suspension setup to use if I want to have a drag suspension type of stiffness. I hope to eliminate all the wheelspin off-the-line.
Are there any manufacturers that actually make "drag kits" or drag suspension components for our cars? I have a 95 SE.
Thanks!
Old Nov 14, 2002 | 10:57 AM
SuDZ's Avatar
Re: Drag Suspension
Thanks!
There is not a specific application but to get ris of the wheels hop try looking into like KYB AGX struts and set them for 4 and 8. That should stiffen it up a lot for you. Also check out warpspeed performance's webpage. They re finally getting going on the Radial arms which will help even more.
SuDZ
Old Nov 14, 2002 | 11:25 AM
Dave B's Avatar
Not DAVEB the parts guy
Re: Drag Suspension
The only way to eliminate the spin is to add slicks. A stiff suspension will help, but tires are the key.
Dave
Old Nov 14, 2002 | 11:33 AM
Jime's Avatar
Re: Drag Suspension
Thanks!
You don't want to eliminate ALL wheelspin off the line. If you do that, something will BREAK. But you do want it to be as minimal as possible.
What you want to do is eliminate as much weight transfer as possible, I do that by blocking the rear suspension so their is no movement. Check in my 1.8 video how much the rear springs compress, thats how you get out of the hole quickly.
Jim
PS YES Slicks are mandatory like Dave said if you want a good holeshot.
Old Nov 14, 2002 | 12:39 PM
speedemn's Avatar
Re: Re: Drag Suspension
SuDZ
Yeah KYB AGX is what I was looking at as well. How about springs? Or would coilovers be better for this purpose?
I was considering Eibach Pro kit for springs or GC coilovers if I was going the coilover route. Any other option that would be stiffer?
Old Nov 14, 2002 | 01:16 PM
SuDZ's Avatar
Re: Re: Re: Drag Suspension
Well you might look at coilovers. On thing that Ground control does it let you pick how stiff they are etc. I think most people get the 350lbs on each spring but if you want it really stiff can look at like 450 or something.
SuDZ
Old Nov 14, 2002 | 05:33 PM
MardiGrasMax's Avatar
Originally posted by Jime
What you want to do is eliminate as much weight transfer as possible, I do that by blocking the rear suspension so their is no movement. Jim
Can you be more specific on how you do this please?
Old Nov 14, 2002 | 05:37 PM
gtr_rider's Avatar
192.168.1.1
doesnt cattman make 'drag suspension' coilovers?
Old Nov 14, 2002 | 06:36 PM
Jime's Avatar
I use a rubber spacers similar to a bump stop (they will work too). I jack the car up at the track and insert them on the shock rod and tighten up the clamp. The clamp in the picture has been replaced by hydraulic type clamps because the cheapies don't hold up too well. I put in 3 of these spacers or approx 3", this completely covers the shaft. When you drop the car down it sits up a bit but not much and compresses very little. Makes for a rough ride on the return road. If you push down on the rear of the car its almost rigid but really helps out quite a bit coming out of the hole.
I also strap down the front springs to limit their movement to around an inch or so, but that doesn't seem to make anywhere near the difference in limiting the weight transfer as the rear.
Old Nov 15, 2002 | 05:56 AM
StygianMax's Avatar
Re: Re: Re: Re: Drag Suspension
Hey Jime!
Where did you buy the rubber material from? What should I be looking for specifically? I imagine I want something that's fairly dense but not so much that it's hard to "form" around the shock rod.
Do you use two straps per side? What do you use? I should have checked out all these "little" details when I met you late summer!
Thx in advance.
Old Nov 15, 2002 | 06:23 AM
Jime's Avatar
Re: Re: Re: Re: Re: Drag Suspension
Originally posted by StygianMax
Hey Jime!
Thx in advance.
I used those rubber spacers you can get at "Crappy Tire" that fit between the coils that are supposed to stiffen your springs. I cut and shape them on the band saw and sander.
You are right to want it fairly dense but not solid, you do need a bit of movement or it will be rigid.
Don't bother with the straps, I didn't find they helped much and are a pain to make and install. I used motorcycle strap tiedowns though if you are interested.
BTW I did not originate this stuff so I can't take credit. A lot of the stuff I try was learned back in the 60's with my 70 Challenger and I read a lot too. You can check out this url for some good info on just how much blocking helps.
http://www.cnw.com/~redline/launching.htm
Jim
Old Nov 15, 2002 | 06:45 AM
StygianMax's Avatar
Re: Re: Re: Re: Re: Re: Drag Suspension
Jim [/B]
That's great info on that link. Thx.
Old Nov 15, 2002 | 07:44 AM
speedemn's Avatar
SuDZ
The GC coilovers will let you get a 450lb spring rate or are you referring to someone else? What is the range of adjustability on the GC? I wasn't able to find this on the website.
What about the cattman coilovers? Are they stiffer than GC? Anyone know the adjustability rate on these?
Thanks!
Old Nov 15, 2002 | 09:30 AM
Jason R's Avatar
aka UNCDooD
wouldn't the heavy duty urethane engine mounts made bu Place Racing help reduce wheel hop as well?
Old Nov 15, 2002 | 10:54 AM
SuDZ's Avatar
Thanks!
Now this was about a year ago.... but I called and they said they could bump it up almost to anything I wanted, they would mail me out the new stiffer spring rates for like 50 bucks over the regular price or could even sell them to me later on and have it installed myself. I did not see it on thewebsite but called and the guy who I talked to mentioned this. Do they still do it, was the guy just wrong, I have no idea but this is what he told me.
SuDZ
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
