manual vs automatic
Old Nov 18, 2002 | 10:12 AM
  #41
Stephen Max's Avatar
Originally posted by bags533
my cat's breathe smells like cat food
Go banana!
Old Nov 18, 2002 | 10:13 AM
  #42
TonyGotSkilz's Avatar
true but,
Everyone here seems to be really concerned with quarter mile times so yes the gearing is better with 5 speeds but if a 4 speed runs lets say .5 seconds less than a 5 speed normally, and this mod shaves off some tenths of a second, does it not mean that the 4 speed will be closer to the 5 speed in the quarter? I'll answer that, yes it does. Like i said this is just "butt dyno" and speculation but i'm pretty sure that it does make the an auto quicker because you don't waste seconds inbetween years. Its the same effect as learning how to shift a 5 speed really well. You lose ET time.
Old Nov 18, 2002 | 10:31 AM
  #43
MaxSpeedSE's Avatar
Its not as simple as that, a 5 speed puts more hp down to the wheels ... take two stock maximas, one 5 speed one auto.... and have them race from off a role..put both in 2nd gear at 45 mph, where both are in power band, and then gun it, and the 5 speed will pull, before even getting to 3rd gear.... threw the gears, a 5 speed pulls harder
Old Nov 18, 2002 | 10:41 AM
  #44
Bags's Avatar
VG Ridah's Biatch Hoe
Originally posted by MaxSpeedSE
4 long gears will not have the off the line and top end of 5 gears
the top end part is not correct
Old Nov 18, 2002 | 10:50 AM
  #45
True. The manual tranny 5th gear has a lower final drive ratio than the automatic's 4th gear.
Old Nov 18, 2002 | 11:05 AM
  #46
MaxSpeedSE's Avatar
yes, but the whole 4th gear of a auto is streached from 120-140
while as a manual its split between 4th and 5th
Old Nov 18, 2002 | 11:20 AM
  #47
Not sure what you're saying here...
Old Nov 18, 2002 | 11:30 AM
  #48
Bags's Avatar
actually it can be streched from around 120MPH ( or lower ) to about 175 MPH
Old Nov 18, 2002 | 12:48 PM
  #49
RastaManMax's Avatar
That's actually quite scary, but is somewhat true... It's just that we don't have the horsepower or aerodynamics to be able to run out 4th gear all the way
LEMAR
Old Nov 18, 2002 | 01:03 PM
  #50
Bags's Avatar
LEMAR
aerodynamics can be overcome with HP.. But your CORRECT, a stock max could not.
I am sure there are 1 or 2 mods that can overcome this
Old Nov 18, 2002 | 01:59 PM
  #51
MaxSpeedSE's Avatar
Our cars top out at 175
Old Nov 18, 2002 | 02:08 PM
  #52
No. That's the speed calculated at redline for an automatic. That is not taking into account the horsepower needed to get there, which is considerably more than what a stock Maxima can provide.
Old Nov 18, 2002 | 02:12 PM
  #53
MaxSpeedSE's Avatar
Well im no were near stock
what kind of hp would it take to get there, im asuming around 300 becuase thomas had 280 and could hit 170
Old Nov 18, 2002 | 02:18 PM
  #54
Well let's see. Power is proportional to speed raised to the third power, so if 280 hp gets you 170 mph, then 280*(175/170)^3 is 305 hp plus some change. Good guess.
Old Nov 18, 2002 | 02:24 PM
  #55
MaxSpeedSE's Avatar
Thanks bro
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
