Wider tires + Traction
Old Nov 18, 2002 | 08:19 PM
speedemn's Avatar
I have the stock size 215/60/15 on my 95 SE. The tires are performance all-season tires (Goodyear Eagle GTII - T rated). I am thinking about getting high performance all-season tires in 15" (Toyo Proxes TPT - H rated). However, I am considering going to 225 for better traction and handling. My question is two-fold.
1) I found that 225/60/15 makes the overall diameter go from 25.2" to 25.6" which translates to 787 revs/mile as opposed to stock 802 revs/mile. The speedo is off by 1.9% (lower). 225/55/15 makes the overall diameter go to 24.7" which translates to 815 rev/mi and the speedo is 1.6% too fast. Which one would you guys pick?
2) Should I scrap the idea of 225 and stick to stock 215 since I am getting a better tire? Do I assume that I will have better traction with these new (better) tires with the stock size or should I get wider? I don't want to compromize acceleration due to the increased resistance because of the wider contact patch of the rubber to the ground. Does the 10mm make that much of a difference in acceleration? Obviously handling will be better, but how much better and is it worth the loss in acceleration, if any?
Hope someone can help me here.
Thanks!
Old Nov 19, 2002 | 09:21 PM
BEJAY1's Avatar
Conecarver
1) 55 series will handle and accelerate better.
2) A grippy 215 tire will always outperform a mediocre 225 width. 10mm wider alone won't affect your acceleration. But a 215 with more steel belts, that weighs 4lbs more would be slower than a ligher 225.
Old Nov 19, 2002 | 09:29 PM
Cutler's Avatar
should help, wider tires always helped on traction. Have to be carful,, they tend to hydroplane easier
Old Nov 20, 2002 | 06:07 AM
Rickalodeon's Avatar
Regarding hydroplaning: As a general rule, that's probably true. But I think tread design has much to do with it. I had Michelin MXV4 205/65-15's and went to Bridgestone Potenza 225/55-16's. The difference is like day and night in favor of the Potenza's.
Old Nov 20, 2002 | 06:21 AM
mzmtg's Avatar
Minister of Silly Walks
There are much better tires out there than the Proxes TPT for the same money. Most ORGers recommend the Bridgestone Potenza RE950and the Dunlop Sport A2.
Old Nov 20, 2002 | 07:04 AM
speedemn's Avatar
The shop I bought from carries all 3 of those tires and he said that with the Dunlop SP Sport A2 I would get worse snow traction and with the RE950 I'd get crappy wet traction.
He said that in terms of tread life, dry traction and wet traction, you can't beat the TPT. As for snow, neither of them are really any better than the other. Dunlop doesn't have as long a life.
Old Nov 20, 2002 | 07:07 AM
mzmtg's Avatar
I have the 950's they have great wet traction. And it's looking like they will last me over 50k miles. Snow traction is not an issue for me, so I can't comment on that.
Personally, I put more stock in what users say than what dealers say. Ask around...
Old Nov 20, 2002 | 07:14 AM
As far as a source for tire reviews go....
- Tire shops (if you can trust them) are mediocre at best, even if he polled all of his customers. For that matter, my best friend would only be mediocre in that he is only one opinion.
- Maxima.org is the best place to get feedback on what works best on our Max's. Lots of actual experience.
- Tirerack.com has a lot of reviews, ratings, tech specs, etc.
Best to compile all of the facts along with all of the opinions.
Old Nov 20, 2002 | 07:54 AM
NYCe MaXiMa's Avatar
I'm starting to really like you
Another thing
while a 225 series might provide slightly better control in turns..
wider does not equal better in snow...
I have tried 225/50/16s before and went with the OEM reccomended 215/55/16 this time and it satisfies me well.. If it's a good tire, that extra .05 of an inch in the sidewall will not play a difference at all. i rather get better tires in the correct size than pay same $ for mediocre tires...
Old Nov 20, 2002 | 10:14 AM
Lime's Avatar
strangely enough, I've always had wide tires on my car... 225/40's that are crappppppy tires, and 225/60's that are great. The 225/60's don't like the cold as much though...time to go back to the 40's which were ONLY good in the snow. No more 125mph runs to work anymore. :'(
Old Nov 20, 2002 | 10:21 AM
96BLUMAX's Avatar
My 235 width tires get great traction and the 40 profile helps handling a lot because less tire wall flex.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Garrettz459
Sep 28, 2015 02:50 PM
