Quick response needed on buying a transmission...
Old Nov 20, 2002 | 11:41 PM
maximumpower96's Avatar
i have 96 5 speed non slip differential transmission which i messed up by putting unorthodox racing clutch stage 3 anyway.. now i am in the market of buying a new tranmission just want to know.. can i fit a lsd transmission in my car no or a 99 or 98 transmission would fit in my 96 maxima or no ? i tried calling dealers but they are so pathetic when it comes to giving out info.. please advice.. thanx
Sal
Old Nov 20, 2002 | 11:54 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Quick response needed on buying a transmission...
definately can, the 5 spd w/lsd does require a new axle... someone else confirm this, I believe it's the drivers side....
Do a search and you'll find it... it'll fit for sure, just not sure bout which axle u need to buy.
Old Nov 20, 2002 | 11:57 PM
Re: Re: Quick response needed on buying a transmission...
thanx for your info.. will look into that thread
sal
Old Nov 21, 2002 | 08:11 AM
mtrai760's Avatar
'Trynna' is not a word
It fits, but the wiring harness is different for a 97+ I believe, it states it in the Haynes, Chiltons, FSM, etc. It's just a matter of changing 4 wires around, not hard at all. You will need to replace the drivers axle, it is bigger/thicker than the non-vlsd, though harold (hlh) changed to a vlsd without changing his axles...
Old Nov 21, 2002 | 08:30 AM
hlh0501's Avatar
I want to say it is 95-97 and 98-99 that have the slight wiring differences, I know i know, it didnt go with the body change as you expect if i remember correctly.
and yes, LSD fits. I did not change shafts either and have NO problems at all from them to date, knock on wood. and i race regularly and you can imagine my shafts get a little strain with turbo and all haha. but then again my car was 5spd conversion before I converted to LSD, so I dont really know what shafts are in there anyways
Old Nov 21, 2002 | 08:45 AM
SpeedCrazie's Avatar
How about, just swapping in a 97+ AUTO transmission into a 95 auto any problems?
Old Nov 21, 2002 | 01:05 PM
Hey, harlod what kinda clutch you using there ? and thanx for the info.. i appreicate it
sal
smplyamzng
Dec 13, 2015 01:19 PM
schmellyfart
Sep 25, 2015 04:47 PM
TonyJr
Aug 20, 2015 12:14 AM
Slamrod
Aug 10, 2015 12:33 PM
yat70458
Aug 3, 2015 01:16 PM
