Installing MEVI, tach signal? HELP
Old Nov 21, 2002 | 04:43 PM
DougsfastZ's Avatar
All Black Max
I'm in the middle of my MEVI install and I can't find where to tap the Harlan switch for the tach signal. Where is the best place to tap the tach signal under the hood?
Thanks,
Doug D
Old Nov 21, 2002 | 04:54 PM
Keven97SE
Re: Installing MEVI, tach signal? HELP
Tap into the harness wires going to one of the coil packs in the front engine bank. I don't know what wire though. Hopefully one of the others will chime in here soon.
Shouldn't be hard to figure out what wire it is if you have a field service manual. One wire is +12V, one is ground, and the other is the signal. You want the signal one.
And make sure to set your Harlan switch to coil-on-plug config, not 6-cylinder.
Thanks,
Doug D
Old Nov 21, 2002 | 05:13 PM
mtrai760's Avatar
'Trynna' is not a word
It's the only wire with a stripe on it, I believe it's green/red.
Old Nov 21, 2002 | 05:14 PM
gtr_rider's Avatar
192.168.1.1
http://www.vqpower.com/v2/modules.ph...howpage&pid=40
Old Nov 21, 2002 | 10:01 PM
DougsfastZ's Avatar
All Black Max
Awesome, thanks guys.
This intake is so nice. Check out my other post about the install.
Doug D
Old Nov 28, 2002 | 11:46 PM
96_vqmax's Avatar
Re: Re: Installing MEVI, tach signal? HELP
so how do you set your Harlan switch to coil-on-plug config, not 6-cylinder?Thanx!
Old Nov 28, 2002 | 11:49 PM
96_vqmax's Avatar
is it the coil plug on #2 cylinder?Thanx!
BkGreen97
Apr 2, 2016 05:47 AM
chernandez1278
Sep 16, 2015 01:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
Steven Orozco
Sep 12, 2015 10:41 PM
