Please Help, Tranny?clutch? Problem?
lately, when it has been cold, my car seems to no want to get into gear, i.e., i will let the clutch out, for example, between 2nd and 3rd, and the car will not quite be in gear, i will give it gas and the engine revs a bit without pushing the car, then a second later, its in gear. whats worse than this, the past couple of mornings (quite cold) i CANT PHYSICALLY STICK THE SHIFTER IN ANY GEAR from a stop with the clutch in....what does this mean???????
thanks for the help
thanks for the help
It means the Maxima's transmission is very ***** when cold and it must be driven SLOWLY until it is warmed up. When slowing to a stop, downshift and let the clutch out briefly in second before you go into first. This makes it easier to synchronize the gears before you engage first.
Re: Please Help, Tranny?clutch? Problem?
thanks for the help
thanks for the help
Do you have a shortshifter? Usually you feel alot more "stiffness" wit the short shifter. I have problems going into 3rd gear at times, but i learned to adapt.
Re: Re: Please Help, Tranny?clutch? Problem?
no, no short shifter, and this is a new problem....didnt happen any other cold season
Originally posted by nadir_s
it means you need to get synthetic tranny oil (redline MT-90)
Re: Re: Re: Please Help, Tranny?clutch? Problem?
03-12-2020 12:06 AM
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
